ebinmaine 67,687 #1 Posted March 1, 2021 I ordered a throttle cable for the Charger 12 which is the push pull type same as on a 1257 or 1267. The one I got is several inches too short. What is the CORRECT LENGTH and where do I go about getting a couple? THANKS! @OldWorkHorse 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,606 #2 Posted March 1, 2021 34 minutes ago, ebinmaine said: I ordered a throttle cable for the Charger 12 which is the push pull type same as on a 1257 or 1267. The one I got is several inches too short. What is the CORRECT LENGTH and where do I go about getting a couple? THANKS! @OldWorkHorse Hhhmmm... Can’t help with the measurements, but you could drill some holes, relocate the engine back a few inches, change pulleys and belts, etc... seems that’s the approach that many previous owners use to “fix” stuff... 1 5 Share this post Link to post Share on other sites
Achto 27,621 #3 Posted March 2, 2021 2 hours ago, ebinmaine said: The one I got is several inches too short. That's odd. Every one that I have ever bought had to be cut down. Share this post Link to post Share on other sites
ebinmaine 67,687 #4 Posted March 2, 2021 8 minutes ago, Achto said: That's odd. Every one that I have ever bought had to be cut down. Agreed. I got one for another push/pull 12 horse that was quite long. What part number do you order??? Share this post Link to post Share on other sites
Achto 27,621 #5 Posted March 2, 2021 3 minutes ago, ebinmaine said: What part number do you order??? I order this one from psep.biz - ROT9135 1 Share this post Link to post Share on other sites
ebinmaine 67,687 #6 Posted March 2, 2021 1 hour ago, Achto said: I order this one from psep.biz - ROT9135 I can't figure out how to find that in the site. Share this post Link to post Share on other sites
OldWorkHorse 3,045 #7 Posted March 2, 2021 http://www.psep.biz/store/toro_mower_cables.htm 1 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #8 Posted March 2, 2021 Looks like S290148 right below ROT9135 would be the choke cable looking for? #102119 and #102118 1 Share this post Link to post Share on other sites
ebinmaine 67,687 #9 Posted March 2, 2021 2 minutes ago, OldWorkHorse said: http://www.psep.biz/store/toro_mower_cables.htm Awesome. Thanks Steve. Now that one lists a 48" housing. That would work... Share this post Link to post Share on other sites
OldWorkHorse 3,045 #10 Posted March 2, 2021 If you think they seem right I might just order a set here. Let me know thoughts. Share this post Link to post Share on other sites
ebinmaine 67,687 #11 Posted March 2, 2021 1 minute ago, OldWorkHorse said: If you think they seem right I might just order a set here. Let me know thoughts. Be happy to. I won't be able to check until tomorrow evening though. If you order... Get at least 2 or 3 of each please. I'll buy em from you and split the freight. Share this post Link to post Share on other sites
OldWorkHorse 3,045 #12 Posted March 2, 2021 1 minute ago, ebinmaine said: Be happy to. I won't be able to check until tomorrow evening though. If you order... Get at least 2 or 3 of each please. I'll buy em from you and split the freight. OK I'll will freight is set 7.95 for hole order. There web page lil sketchy so might hold off and call them on phone tomorrow. 1 Share this post Link to post Share on other sites
ebinmaine 67,687 #13 Posted March 2, 2021 7 hours ago, OldWorkHorse said: OK I'll will freight is set 7.95 for hole order. There web page lil sketchy so might hold off and call them on phone tomorrow. The web page is tough. I've bought from them as well as multiple other folks here. Had good luck so far. @Achto I was mistaken about the cable. It's the CHOKE cable that's too short. It doesn't wrap under the engine. Is it supposed to? Share this post Link to post Share on other sites
Achto 27,621 #14 Posted March 2, 2021 1 hour ago, ebinmaine said: It's the CHOKE cable that's too short. It doesn't wrap under the engine. Is it supposed to? It should go over the battery, slide through between the block and the aluminum bearing plate and then up to the choke. It is usually a tight fit between the block and bearing plate. I have one tractor that I had to shave some of the rubber casing off to gain clearance. Can't seem to find a picture. I'll try to remember when I get home today. 3 1 1 Share this post Link to post Share on other sites
ebinmaine 67,687 #15 Posted March 2, 2021 42 minutes ago, Achto said: It should go over the battery, slide through between the block and the aluminum bearing plate and then up to the choke. It is usually a tight fit between the block and bearing plate. I have one tractor that I had to shave some of the rubber casing off to gain clearance. Can't seem to find a picture. I'll try to remember when I get home today. Okay okay I gotcha... No worries on the pic Dan. I'm pickin up what you're putting down. 1 Share this post Link to post Share on other sites
squonk 41,164 #16 Posted March 2, 2021 You can see how it goes thru the brg plate and up thru and out on the Skonkmobile. 1 1 1 Share this post Link to post Share on other sites
cafoose 3,355 #17 Posted March 2, 2021 3 hours ago, ebinmaine said: I'm pickin up what you're putting down. 2 Share this post Link to post Share on other sites
ebinmaine 67,687 #18 Posted March 2, 2021 Just now, cafoose said: Hahahahaha The story of my life right there. 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #19 Posted March 4, 2021 On 3/1/2021 at 7:00 PM, Achto said: That's odd. Every one that I have ever bought had to be cut down. Same here.Most are way too long.BTW,after all these years fooling with throttle and choke cables on numerous equipment,I finally bought a pair of z-bend pliers to put that neat little bend on the end.So much easier than trying to bend the cable with 2 pairs of needle nose pliers.And,a perfect bend. 2 Share this post Link to post Share on other sites
