Bow_Extreme
50” Grader Blade
Bow_Extreme
Question.  A friend of mine has the 50” grader blade(79351).  He has a 314-8 tractor. When he places the link onto the upper rock shaft hole, at full lift position, the blade will barely come off the ground.  The link is basically the solid link, about 11-3/4” total length and 10-3/4” pin to pin.  Anyone else had issues with lifting the blade?
I’m not anywhere near close to him so I can’t directly put my eyes on this and trouble shoot his issues.
Pullstart
Maybe a shorter link is needed?
I’d lock it in full lift, then lift the blade to the frame, then measure the hole to hole distance for comparison...
  • Excellent 1
Bow_Extreme
Kevin,
Thank You. I had exactly the same thoughts.  I did step him through all of the instructions and pictures.  I believe he has now successfully made this work.  I think he tried using the wrong rock shaft tab.
Thank You!!
