Similar Content
By Bill Winn
For sale. NEW LOWER PRICE 1981 WH C-175 Kohler twin series 1
1. Tractor has brand new ag tires all the way around, brand new seat, new points and condenser, new rear blade quick attach bracket, lights have been rewired with LEDs, it has a brand new lift cable and bracket,seat pan is from a 410... it's surface rusted but at least it isn't busted up like the oem plastic one, starts and runs but smokes a bit on startup if it's been sitting for months but she runs smooth and strong.
2. Tiller is like new. It had been used only about once when I bought it and now it has been used 4 times more. Tines still have much of the factory paint on them. Tiller is no longer included in this listing.
3. 42" mower deck works perfectly, 4. snow blade was/ is rough but I repaired it so it is quite functional,
4. Brand new rear grader blade,
5. Wheel Horse brand plow,
6. Wheel Horse brand disc- I added a piece of motorgrader blade for a drag. I also welded a post to the top to hold weights,
7. Wheel Horse brand cultivator,
8. Home built furrower. (Makes good rows)
The original Wheel Horse plow/disc/cultivator originally came as a modular kit and in order to use it the draw bar and clevis hitch had to be swapped back and forth. (big pain) I fabricated draw bars and hitches onto each piece so this is no longer necessary.
I think this is a fair asking price at $1,400 for all. text (ate-oh-fore) too free nein - too oh too sevin
By Joe Reese
60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great Joe Reese
By Jayzauto
I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint. Engine has been replaced with an identical Kohler KT-17 Series 1. New Carb has been installed. Battery, solenoid and cables have been replaced, starts great. Installed new Tires and Tie Rods. Installed radial bearings in spindles, so it steers beautifully. Fuel line has been changed, as well as headlights. Bew mule drive and belt fot tiller and functions as designed. I'm sure there is other items that have been done. Very reliable machine. $800/BRO
Selling all my WheelHorse items and moving South. Have other tractors ad parts if interested.
By HumbleHans
Operator manual 810343R1
Wiring
34 pages 17.5MB
Wiring Colored
1 page 228KB
1984 C-105 8-Speed model 11-10K802
1984 C-125 8-Speed model 11-12K802
1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
1984 C-165 8-Speed model 11-16K801
1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
1984 C-195 Twin Automatic model 01-19KE02
By Brockport Bill
520 HC Tractor For Sale: please see photos; Just 630 hours on meter. Powerful Onan 20 HP motor. Hydro transmission, Hydro lift. This HC was limited 2 year production, top of the line Wheel Horse commercial model - including swept front axle. Cleaned and serviced, new Carburetor, new plugs, new engine oil, new tranny oil, new battery, new decals, new foot treads, rebuilt hydro lift cylinder, zerk fittings all lubed, tires hold air, headlight rims. Seat adjust feature. Cash pick up as is, Hudson River Valley, Poughkeepsie, NY area. Tractor only, priced at $1,550. Also available as option: Rehabbed 48 inch side discharge mower deck, professionally sandblasted shell plus lift carriage assembly to remove rust and paint; then newly primed and painted. Plus new hardware. Blades cleaned, sharpened and balanced. Mower deck available at $ 440. Please send p.m. for questions or info?
