Similar Content
By Jayzauto
I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint. Engine has been replaced with an identical Kohler KT-17 Series 1. New Carb has been installed. Battery, solenoid and cables have been replaced, starts great. Installed new Tires and Tie Rods. Installed radial bearings in spindles, so it steers beautifully. Fuel line has been changed, as well as headlights. Bew mule drive and belt fot tiller and functions as designed. I'm sure there is other items that have been done. Very reliable machine. $800/BRO
Selling all my WheelHorse items and moving South. Have other tractors ad parts if interested.
By HumbleHans
Operator manual 810343R1
Wiring
34 pages 17.5MB
Wiring Colored
1 page 228KB
By Brockport Bill
520 HC Tractor For Sale: please see photos; Just 630 hours on meter. Powerful Onan 20 HP motor. Hydro transmission, Hydro lift. This HC was limited 2 year production, top of the line Wheel Horse commercial model - including swept front axle. Cleaned and serviced, new Carburetor, new plugs, new engine oil, new tranny oil, new battery, new decals, new foot treads, rebuilt hydro lift cylinder, zerk fittings all lubed, tires hold air, headlight rims. Seat adjust feature. Cash pick up as is, Hudson River Valley, Poughkeepsie, NY area. Tractor only, priced at $1,550. Also available as option: Rehabbed 48 inch side discharge mower deck, professionally sandblasted shell plus lift carriage assembly to remove rust and paint; then newly primed and painted. Plus new hardware. Blades cleaned, sharpened and balanced. Mower deck available at $ 440. Please send p.m. for questions or info?
By Foxer14
My grandfather is selling his C-175 and I want to buy it from him to restore it. He thinks he can get about $3000, but I think that is too high. It does come with a mower deck that is probably to rusty to use and a tiller. He says the tractor has lots of accessories on it. It will need some work as it hasn't ran in probably 15-20 years. I was thinking about $1000 but I am not sure. What do you think?
By Josh Opitz
I have redone most electrical components and fuel of this kohler K341. new spark plug, coil, starter, battery, rectifier, Carb, rewired, but i have not done points. it starts up great idols fine. when I turn the throttle up it rises up to a certain RPM then starts to seize and puff black smoke and the throttle on the the carburetor jumps. Someone had told me it is backfiring and said i need to adjust the my air to fuel ratio. started messing with the governing arm and spring and thought it was helping but hasn't fixed it. any suggestions?
