WHX??
K161 Flywheel
squonk
Spray it with carb cleaner and go have a couple of brewski's. The crack will show up and you'll be using that flywheel for an ashtray.
  • Haha 4
DennisThornton
1 hour ago, Gregor said:
I'll never use a rattle gun on a flywheel again.  Learn something new everyday. I was able to get a new flywheel for my K161 from Lincoln.
Hopefully my wife will let me use one of her torque wrenches. :lol:
Impacts are great in reverse!  Got to be careful or grab another wrench for the other direction.
Pullstart
Uncle Jim’s an hour behind us, ya know... well... never mind... it’s Uncle Jim.
  • Haha 2
8ntruck
Or spray with penetrating oil, let it set 5 to 10 minutes, then spray with carb cleaner to clean the surface, then sprinkle with talcum powder.  The powder will draw some oil out of the cracks and make them visible.
Dye check kits do the same thing, but with red dye instead of the oil and an aerosol spray powder.
Edited by 8ntruck
  • Thanks 2
DennisThornton
I had forgotten that trick!
Thanks!
squonk
Late 80's 4bbl GM305 engines. Using antifreeze with no sign of a leak. Pull the intake. Spray the lifter valley with carb cleaner. go have a cup of coffee. Come back and there are the cracks! :banana-wrench:
(Same thing with the 3.1 V-6 only it was the rear driver side cylinder) :banana-wrench:
Edited by squonk
WHX??
Crap.... :crying-yellow:..... strike two..... off of Dan's carcass.
  Found one on fleabay for 60 clams but keep yours on hot standby Kev. Seller says its for a JD 110 but has same casting numbers. I would paint it Red tho. I would  be booted out the club I bought would I?
Edited by WHX24
DennisThornton
Darned!  Wonder why it's available?
WHX??
Guy had specific pics of the keyway area Dennis ...I don't  wanna post a :text-link:.... club rules ya know.
Evidently this flywheel was used on a few spec engines.
Edited by WHX24
