TJ5208
Duals and YouTube channel
pfrederi
1 hour ago, Tj salyers said:
Has anyone ever swapped a transmission from a raider 10 how do they mount up
What model tractor is the donor???
TJ5208
Okay I got the front weights done so check out my YouTube channel and I will have to put longer bolts for that that goes probably all the way through carriage bolts so it'll hold it better
TJ5208
I'm not sure what model it is but it's a Raider 10 and it's in pretty good condition it's been sitting for a few years but I'm hoping I can maybe swap it out for the peerless I  pictures of them could help anything could
pfrederi
You have to give a bit more info.  Donor Raider 10  what are you putting it into???   Anything using a peerless would not be a easy candidate for transfer
TJ5208
800 special new pics first time in snow since I got him in thinking about sticking concrete blocks  in between the transmission and the frame I'm hoping that will help if I can put them out to slab concrete blocks in there so that'll easily weight like 80 or 60 lb  did good in snow front end gets pushed alout tires spun a few time I'm happy with him did this just now
TJ5208
Any picture of a raider would help
TJ5208
And also If you guys would like a picture of the transmission mount on ole red would that help
Achto
Show us a pic. I've never seen a Peerless in a :wh: with a horizontal shaft engine. If the mounting plate is the same as a uni drive tranny, your planned swap might be fairly easy.
Lane Ranger
Yes the 800 special is a kind of unique Wheel Horse!   My brother has one pretty original!  I think it was a 1972 or 1973 tractor that Wheel Horse had a strike and so only managers were available to assemble tractors.  The 800 special had a 9 hp Briggs motor and a special Peerless transmission.  The rear frame on the 800 special was different also to accommodate the Peerless transmission.
This is all documented in the Mike Martino book, “Straight from the Horses Mouth”!
Edited by Lane Ranger
TJ5208
I'll get pictures I'm at Menard's right now so the tractors made in 1971 and it has a 8 horse Briggs & Stratton engine on it so I get will get pictures soon
Edited by Tj salyers
TJ5208
pfrederi
Any thing is doable given time, money, stuff and skill.  But putting a Raider tranny on this machine would not be a quick easy project.
TJ5208
I just asked my dad if I could fill my tires are the antifreeze and he said no so I'm going to try to fill in pool water I guess why you saying that is because the tires won't hold is there so old so maybe if I just use water it won't waste much
TJ5208
Do you guys think I should just stick with the Peerless or swap because it seems nice and sturdy and I can cut the concrete blocks in between it
Jeff-C175
And when it freezes?  What then?
TJ5208
Don't use him in the winter
pfrederi
This is the best pic I could find right now as to how a Gear Transmission like on a Raider would mount to a WH frame.  Significantly different than the Peerless mounting... Regular trany bolt frpm th e front of teh tranny directly to a plate on the end of the frame.  The peerless mounts from the sides.
TJ5208
It will make him weight more and more traction with duals the peerless has a big axle do that will help fill a back fours maybe if  I can get duals
TJ5208
That's how his mounts
TJ5208
You should be able to mount it
TJ5208
I didn't mean pool water
TJ5208
Found the model number it is a 1970 raider 10 20210223_161429.jpg.2dd937862f9f304bec73963b4a45fcd7.jpg
TJ5208
Hers some atv tires maybe a fender lift
Achto
If it were me, I would leave the 800 the way it is and try to get that Raider 10 to make into my heavy worker. :twocents-twocents: The Raider has a bigger engine and much stronger transmission. It also does not look too bad in the picture, kind of hard to tell with the stuff around it.
Your 800 is kind of a rare set up with the peerless transmission, this may add value to it down the road.
TJ5208
Text Diane I might think of that if my dad will give it to me I will probably just leaving saying for my heavy worker so I'll see what happens it's in Nice condition to
