snowhound 105 #1 Posted February 21, 2021 My son found red spots in the snow after plowing and found the transmission ( 8 speed ) is low on lube. What is the recommended lube for that transmission? Share this post Link to post Share on other sites
DennisThornton 4,769 #2 Posted February 21, 2021 Not red stuff! Unless some brand has come out with red 90-140W. Check the shifter boot too! They crack and let water seep in. Makes a milky mess. Might get some more feedback from the others but I drain the mess, fill with kero/diesel and run around for a few minutes and drain and fill with the 90-140w. Might want to do it again if still milky. Others might suggest another fluid to flush and they might be right. I just don't think a few minutes under light load with kero is much worse than the milky crap and you really do want the water out somehow. Others will chime in soon. 2 Share this post Link to post Share on other sites
stevasaurus 22,862 #3 Posted February 21, 2021 right...90-140 wt GL-5 1 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #4 Posted February 22, 2021 23 hours ago, stevasaurus said: right...90-140 wt GL-5 1 Share this post Link to post Share on other sites
