Workin_Horses
C160 Transmission oil
william y
no that is tight
Trouty56
If the only thing you did was change the motor cover then I would look at it again.....download the manual for the hydro tranny
and try to fix that area.
william y
thank you for the info
william y
the belt was the problem and know it works like a charm and thanks for the info
Trouty56
Cool deal William!!! I'm glad you got it figured out....
william y
there is another problem, was there a difference between the linkage in the c141 and the c121 and also when the wheel horse transmission is engaged it still rolls freely.
can whlvr
is it not normal for a sundstrand to roll unless the roll valve is open,and i would think the linkage would be the same,exactly even
