Vinny
Transmission problems
Vinny
So recently I’ve been having a problem with my 80s model 312-8 story on it is that I got it from my uncle who passed away and it wasn’t running I got it running but not driving because it had the automatic transmission that no longer worked so a buddy and I swapped it out for a 312-8 transmission now he ended up putting a broken dog screw in for the donut and it snapped and the donut fell into the transmission I tore everything apart got the transmission off took all the bults out but I can’t seem to get the trans to break apart can someone help me I need the tractor for thus summer for clean up jobs
oliver2-44
Do you have the hitch pin out at the rear of the transmission?
I take a thin putty knife or a wood chisel and start at a corner an tap it in  and work my way around to break the gasket loose.
Vinny
I’ll give that a try now when I break this apart the gears Arnt just going to fall apart on me are they because I’ve never worked on a transmission for a tractor before
953 nut
:WRS:
This thread by @stevasaurus should get you started on a successful rebuild. You can find a new gasket and any other parts you'll need at Wheel Horse Parts and More.
 https://wheelhorsepartsandmore.com/
Pullstart
:text-welcomeconfetti:  Try checking out @stevasaurus’ video tutorials, he explains everything very well!
Pullstart
@953 nut beat me by seconds :ROTF:
  • Haha 4
Achto
:WRS:
If you can tip the tranny so that the right hand side is down, you should not have an issue with the gears falling out.
roadapples
:text-yeahthat: brake side up...
horseyheaven
I always do them right side down.  If you leave right rear tire on, it makes a nice stand.
