Achto 27,565 #151 Posted June 10, 2021 Yes sir!! What ya gotta have for it? Share this post Link to post Share on other sites
squonk 41,067 #152 Posted June 10, 2021 We'll figure it out at the show. It will depend on how nice Jim is to me! 9 Share this post Link to post Share on other sites
WHX?? 48,814 #153 Posted June 10, 2021 36 minutes ago, squonk said: how nice Jim is to me! Best bring lots o cash Dan! 8 Share this post Link to post Share on other sites
Achto 27,565 #154 Posted June 10, 2021 Thanks @squonk !! There's no way to curb Jim's behavior, so I'll just make sure to pad my wallet appropriately. 4 Share this post Link to post Share on other sites
Wheel Horse 3D 3,792 #155 Posted June 10, 2021 On 6/8/2021 at 10:52 PM, pullstart said: The “D” hole in the dash is about 1/2” wide and the knob is about 1-1/4” diameter. I’ve managed to know it’s whereabouts for 2 years but now that I want to measure it’s length it grew legs! Lemme guess...you made the mistake of trying to straighten up, and put it somewhere safe! 2 Share this post Link to post Share on other sites
Pullstart 62,834 #156 Posted June 10, 2021 1 minute ago, Wheel Horse 3D said: Lemme guess...you made the mistake of trying to straighten up, and put it somewhere safe! I found it sitting exactly where I put it... 3 Share this post Link to post Share on other sites
Wheel Horse 3D 3,792 #157 Posted June 10, 2021 1 minute ago, pullstart said: I found it sitting exactly where I put it... Lol SOME LEGS! You now how it goes...stuff is ALWAYS in the last place you look.(Cuz ya quit looking when you find it) 1 1 Share this post Link to post Share on other sites
Ed Kennell 38,136 #158 Posted June 10, 2021 Dumped a couple more buckets. 2 Share this post Link to post Share on other sites
oldredrider 2,548 #159 Posted June 10, 2021 Ed, I'll take those 2 carbs off your hands. Also looking for dipstick and tube (or 2) for big block Kohlers with balance gears. Share this post Link to post Share on other sites
wheelhorseman 3,211 #160 Posted June 11, 2021 Wheel Horse mid mount grader blade $250 Share this post Link to post Share on other sites
cafoose 3,354 #161 Posted June 11, 2021 4 minutes ago, wheelhorseman said: Wheel Horse mid mount grader blade $250 I'll take the grader blade! 1 Share this post Link to post Share on other sites
wheelhorseman 3,211 #162 Posted June 11, 2021 4 minutes ago, cafoose said: I'll take the grader blade! It’s yours 1 1 Share this post Link to post Share on other sites
cafoose 3,354 #163 Posted June 11, 2021 28 minutes ago, wheelhorseman said: It’s yours 1 Share this post Link to post Share on other sites
76c12091520h 3,615 #164 Posted June 11, 2021 NOS Tecumseh clock, has a couple fine scratches from box wear but overall very nice condition with no discoloring. Battery was installed to test it and it works as it should . $50.00 1 Share this post Link to post Share on other sites
Ed Kennell 38,136 #165 Posted June 11, 2021 On 6/9/2021 at 8:30 AM, pullstart said: @Ed Kennell put me down for the one with the dish shaped concave knob (middle). I’m sure Jada will appreciate having all dash controls for the first time ever! I just pulled that one out and it only measures 30" long. It may be too short. We can see what fits at the show. Share this post Link to post Share on other sites
Pullstart 62,834 #166 Posted June 11, 2021 4 minutes ago, Ed Kennell said: I just pulled that one out and it only measures 30" long. It may be too short. We can see what fits at the show. I think you’re right. I was right around 39” I believe. Share this post Link to post Share on other sites
Ed Kennell 38,136 #167 Posted June 11, 2021 I should have room to bring this 855 If any one is interested. Set up with 42" blade and concrete wheel weights and a concrete weight on a sleeve hitch. It starts and drives as it should, but does smoke a little on throttle up. It has been painted and a new low amp ign. switch with a solenoid was added. And no extra charge for the custom color matching flip boat seat, the wheel spinner, or the mounting step. ( look closely at the first pic. right below the lift lever) As shown delivered to the show $550 W/O plow, axle brkt.,weights $425 Send me a PM if interested in any of it. 4 Share this post Link to post Share on other sites
Ed Kennell 38,136 #168 Posted June 11, 2021 (edited) I have two 8 speed transmissions. Both are 1 1/8" axles. #1 has both hubs, but is jammed in 3rd gear. I have not been able to move the fork. It needs to be split to see what is jammed. $40 #2 has no hubs. the axles and keyways and keys look good. Tha axles have been spot drilled for the hub set screws. It shifts thru all gears as it should $50 SOLD Edited June 11, 2021 by Ed Kennell 1 Share this post Link to post Share on other sites
squonk 41,067 #169 Posted June 11, 2021 Once again I'll have my spark plug wire making kit in attendance. For Kohler and Onan twins please measure the length and take pictures of the ends. Better yet, Bring them 2 me and I can match them up. K singles $ 8.00 Ea. Kohler Twins $14.00 Set Onan Twins $ 20.00 Set Also I will have some hood anti-rattle stripping $2.00 a tractor or $2.00 a foot 4 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,315 #170 Posted June 11, 2021 Hood anti-rattle strips! Perfect! I need enough for two machines 1 Share this post Link to post Share on other sites
wheelhorseman 3,211 #171 Posted June 11, 2021 3 hours ago, Ed Kennell said: I have two 8 speed transmissions. Both are 1 1/8" axles. #1 has both hubs, but is jammed in 3rd gear. I have not been able to move the fork. It needs to be split to see what is jammed. $40 #2 has no hubs. the axles and keyways and keys look good. Tha axles have been spot drilled for the hub set screws. It shifts thru all gears as it should $50 I will take them Share this post Link to post Share on other sites
wheelhorseman 3,211 #172 Posted June 11, 2021 Reproduction early tiller brackets $100 at the show - preorders only pm me if interested 4 Share this post Link to post Share on other sites
Ed Kennell 38,136 #173 Posted June 11, 2021 It rained all day, so I had time to explore the back corners of the barn. I found this Charger V7 roller with the Eaton 6 auto. I have tested the hydro and it spun the tires on the pavement. What you see is what you get. Add a rear engine and make a step thru 2 seater or a pickup bed. $50 Wheel Horse branded 23X8.5X12 turf savers small cracks around some of the lugs but no cracks on the sidewalls about 1/4" tread left $40 pair We got chains 4 link $15 2 link $25 Any you pull starters know what these fit? I have some NOS Toro, Kohler, Tecumseh, and Briggs parts come look thru the pile. 6 " fronts on wheels w/ tubes $20 pair 8" fronts on wheels $10 each More PTO stuff K 301 block it turns free $20 3 Share this post Link to post Share on other sites
cafoose 3,354 #174 Posted June 11, 2021 16 minutes ago, Ed Kennell said: We got chains 4 link $15 2 link $25 I'll take a couple sets of 2 link if you got them Share this post Link to post Share on other sites
Wheel Horse 3D 3,792 #175 Posted June 11, 2021 Man gotta go visit Ed's Part Emporium at the show! 2 2 Share this post Link to post Share on other sites
