roy
about to install new deck bearings
roy
Man, didn't realize there were so many parts under my WH 418-A!   Got the deck stripped down, painted with POR-15, 2 coats underneath, one coat on top &   hi-build primer & will do a final red, along with all the linkage, all in Regal Red actually, all I could get with all our stores in lockdown.
My brand New bearings -  I don't want to pound them into place, I;m hoping you guys can suggest a better way to install bearings,
I.E- Heat up the housing, with my gas torch, making it easier to  slip bearings into place, I've read this is a proven method
PS- I did get the Lucas red & tacky grease, oh jeez, I just realized, I guess I won't be packing the housings with grease before I heat em up to install  bearings!
Any Best way to install bearings- I;m all ears
Thanks
Roy
Stepney
Aluminum spindles?
They aren't a tight fit at all. Grab a block of wood and tap them in nice and gently. If you're really nervous, I guess you could heat them and use a thin seal driver that is the OD of the outer race and go about it that way. I've done literally dozens. Never had one come back.
  • Like 5
Ed Kennell
I often use a deep well socket that just fits inside the housing.
roy
Aluminum yep.
I actually tried a test fit last night & your right,  with a small amount of effort I can see bearing bedding in without having to heat em up,  or run to my buddies to use his press.
Thanks fellas!
Roy
roy
Another question for you guys.
Now the mower deck is all fixed up, about to install spindles.
Let me see if I can explain this quickly
- The center post has 2 holes in it, that, when you force grease into the top grease nipple- distributes the grease into the main housing.  The hollow center shaft that sits between the bearings, also has 2 holes in it. There is no way all these holes will line up once the upper & lower bearings are in place.
Are they supposed to line up, to distribute grease??
Thanks for any info
Roy
