DennisThornton 4,769 #176 Posted February 12, 2021 Don't know if I posted an example in this thread but coil over shocks have been used and I think that is a great approach. 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #177 Posted February 12, 2021 1 hour ago, Handy Don said: In this video, you can see that he has a big CMU (concrete masonry unit) on the frame of the idlers that is giving downforce to both the drive wheels and the idlers. In his recap of pros and cons, he mentioned that the idler axles were bending with the weight, so it'd have to be better distributed https://www.youtube.com/watch?v=tTUogBGcAnU I did see the concrete block so I did see at least one attempt to add weight but many haven't. I'd want filled tires and wheel weights AND a load above AND I think a coil over shock. 2 Share this post Link to post Share on other sites
ebinmaine 67,483 #178 Posted February 12, 2021 25 minutes ago, Oldskool said: That ought to give good weight and fairly even distribution Agreed. 8 x 24" pieces are 55 lbs each. Easy to add. 1 Share this post Link to post Share on other sites
ebinmaine 67,483 #179 Posted February 12, 2021 1 hour ago, Handy Don said: In his recap of pros and cons, he mentioned that the idler axles were bending with the weight, so it'd have to be better distributed I'm thinking I'd go with bigger idler axles. Inch maybe? I'd want to be confident the IDLERS would support the weight. Not just the drives. Overkill? Not on my terrain. Share this post Link to post Share on other sites
Oldskool 6,644 #180 Posted February 12, 2021 24 minutes ago, ebinmaine said: I'm thinking I'd go with bigger idler axles. Inch maybe? I'd want to be confident the IDLERS would support the weight. Not just the drives. Overkill? Not on my terrain. Overkill almost never disappoints. 1 1 Share this post Link to post Share on other sites
Handy Don 12,217 #181 Posted February 12, 2021 4 minutes ago, Oldskool said: almost 2 Share this post Link to post Share on other sites
Oldskool 6,644 #182 Posted February 12, 2021 So now we have the idler and drive wheel part of this almost figured out it's about time to start thinking track construction. 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #183 Posted February 12, 2021 4 minutes ago, Oldskool said: So now we have the idler and drive wheel part of this almost figured out it's about time to start thinking track construction. Rear drive? Pivoting, coil over shock rear axle with matching tires? Tracks? I'm leaning to chain and steel bars. Bent shallow U rebar welded to a chain link. Simple and about as cheap as anything. Size of chains? Rebar size? 5/8" rebar and spaced out to look "right" and then choose chain size. I know I don't like 4-link tire chains at all but that might be enough for tracks. Could always add more and it depends on what size the chain links are too. Share this post Link to post Share on other sites
DennisThornton 4,769 #184 Posted February 12, 2021 This was a aftermarket kit for GTs and ATVs so I assume a lot of thought went into it. Yet I'm not sure all this is needed. Much more complicated than others. #1: We are discussing not using item 1 and I see no advantage to having it outside where others build the frame inside of the rears. #2: Is an idler really needed here? Especially if item 3 is the same size as the drive tire? #3: There's clearance to the seat/fender pan to allow for a full 12" wheel and tire in the rear so why not take advantage of that? This Share this post Link to post Share on other sites
Oldskool 6,644 #185 Posted February 13, 2021 24 minutes ago, DennisThornton said: Rear drive? Pivoting, coil over shock rear axle with matching tires? Tracks? I'm leaning to chain and steel bars. Bent shallow U rebar welded to a chain link. Simple and about as cheap as anything. Size of chains? Rebar size? 5/8" rebar and spaced out to look "right" and then choose chain size. Every other link? Share this post Link to post Share on other sites
DennisThornton 4,769 #186 Posted February 13, 2021 1 minute ago, Oldskool said: Every other link? Probably best, but maybe not necessary. Share this post Link to post Share on other sites
Oldskool 6,644 #187 Posted February 13, 2021 10 minutes ago, DennisThornton said: This was a aftermarket kit for GTs and ATVs so I assume a lot of thought went into it. Yet I'm not sure all this is needed. Much more complicated than others. #1: We are discussing not using item 1 and I see no advantage to having it outside where others build the frame inside of the rears. #2: Is an idler really needed here? Especially if item 3 is the same size as the drive tire? #3: There's clearance to the seat/fender pan to allow for a full 12" wheel and tire in the rear so why not take advantage of that? This I would think the bottom idler would be more important than the top. I assume item 1 is what holds all that together and the tensioner as well. Share this post Link to post Share on other sites
DennisThornton 4,769 #188 Posted February 13, 2021 2 minutes ago, Oldskool said: I would think the bottom idler would be more important than the top. I assume item 1 is what holds all that together and the tensioner as well. I should have mentioned 4 items. Why bother with the top idler if #1 is a tensioner? Same assumption here on item #1. What bothers me is that people that I assume make a lot of money thought all that was needed and I want to toss all of it. But I've seen several other examples that seem to work with these items. Share this post Link to post Share on other sites
Oldskool 6,644 #189 Posted February 13, 2021 Just now, DennisThornton said: I should have mentioned 4 items. Why bother with the top idler if #1 is a tensioner? Same assumption here on item #1. What bothers me is that people that I assume make a lot of money thought all that was needed and I want to toss all of it. But I've seen several other examples that seem to work with these items. Just look at any dozer,excavator ,skid steer snowmobile, etc. I think its necessary to a point. Even a conveyor belt Share this post Link to post Share on other sites
ebinmaine 67,483 #190 Posted February 13, 2021 But the isavetractors one has no idler... Share this post Link to post Share on other sites
DennisThornton 4,769 #191 Posted February 13, 2021 16 minutes ago, ebinmaine said: But the isavetractors one has no idler... Several have no idler and seem to work. However, I like prototype designs that have options. Better to plan ahead in case something is needed. If possible... 1 Share this post Link to post Share on other sites
Oldskool 6,644 #192 Posted February 13, 2021 (edited) 24 minutes ago, ebinmaine said: But the isavetractors one has no idler... But it's an open track. Alot of space between cleats. Fine for hard flat surfaces. Not for off road. Without idlers it will twist and walk around alot. Just think of the sticks and stumps that could come up thru it. Edited February 13, 2021 by Oldskool 1 Share this post Link to post Share on other sites
ebinmaine 67,483 #193 Posted February 13, 2021 24 minutes ago, Oldskool said: But it's an open track. Alot of space between cleats. Fine for hard flat surfaces. Not for off road. Without idlers it will twist and walk around alot. Just think of the sticks and stumps that could come up thru it. Yep yep yep..... I was kinda thinking maybe a flat plate there? Or are the idlers full width? Share this post Link to post Share on other sites
Oldskool 6,644 #194 Posted February 13, 2021 Just now, ebinmaine said: Yep yep yep..... I was kinda thinking maybe a flat plate there? Or are the idlers full width? From what I've seen if it has a drive chain it's a narrow idler in the middle. Snowmobiles have 1 on each side.. No drive chain. The idlers on the bottom also would keep the track tight over rough terrain keeping the downward force even over the whole length. Without then most of the force is in 1 or 2 places. Snowmobiles now have sliders because go keep the track flat on the snow Share this post Link to post Share on other sites
Handy Don 12,217 #195 Posted February 13, 2021 The snowmobile tracks are often not as aggressively textured, either. Lots of bogie wheels distributes the load and lets the track conform to the terrain so no one spot is too heavy. Share this post Link to post Share on other sites
Oldskool 6,644 #196 Posted February 13, 2021 1 minute ago, Handy Don said: The snowmobile tracks are often not as aggressively textured, either. Lots of bogie wheels distributes the load and lets the track conform to the terrain so no one spot is too heavy. Things have changed a bit from the old bogie style. Share this post Link to post Share on other sites
ebinmaine 67,483 #197 Posted February 13, 2021 Rugged tread on that bugger too. For us in p'tic'lar it'd be for snow so I'd figure we want a pretty aggressive tread. Share this post Link to post Share on other sites
Oldskool 6,644 #198 Posted February 13, 2021 4 minutes ago, ebinmaine said: Rugged tread on that bugger too. For us in p'tic'lar it'd be for snow so I'd figure we want a pretty aggressive tread. Something like that would work better then an open track in the snow for sure 1 Share this post Link to post Share on other sites
Oldskool 6,644 #199 Posted February 13, 2021 I think they call it a Cross Country track 1 Share this post Link to post Share on other sites
ebinmaine 67,483 #200 Posted February 13, 2021 Just now, Oldskool said: Cross Country track Looks right by search. I'm picturing some sort of maybe 1.5" wide x 1.5" deep C channel welded to a row of chain. Attached wherever convenient then tightened with the idler set being adjustable. Front skis would likely start as (4 x 8"?) Hemlock rough sawn and be refined to a proper shape. Share this post Link to post Share on other sites
