Erby 15 #51 Posted March 25, 2021 Hi, I am also having some drive belt problems on my c 81 1978/9 wheel horse can any one tell me the oem number for this belt ? please.Thanks Erby. Share this post Link to post Share on other sites
peter lena 9,002 #52 Posted March 25, 2021 haydendavid380, make sure you go over EVERY CLUTCH RELATED MOVEMENT POINT WITH AEROSOL LUBRICANT, look for the related rust run out , typically a neglected rusty / crud zone that hangs up the linkage. with the singular rear spring linkage pull ,it should work without effort , and give very smooth engagement. full exposure of the set up and having help , will let you zero in on the problem area, I also add washers and lube to each point , removes the play and increases its function, pete Share this post Link to post Share on other sites
pfrederi 18,211 #53 Posted March 25, 2021 4 hours ago, Erby said: Hi, I am also having some drive belt problems on my c 81 1978/9 wheel horse can any one tell me the oem number for this belt ? please.Thanks Erby. WH #7473 1 Share this post Link to post Share on other sites
