Navig8r
Snowplow pivot mechanism question
Navig8r
So I broke the solid rod that goes from the "release" handle down the "angle" handle to the triangular pivot mechanism..... Anyone ever replace this with a piece of cable instead?  Thinking with a clip in the whole works it would be easy to disconnect to ease in plow removal and installation.....
Any thoughts?  Pics?  (Who doesn't like pics?)
TIA!
pfrederi
TIA!
Yes i used cable on one of my snow horses works fine.
Edited by pfrederi
  • Excellent 2
Pullstart
Yeah, those linkages pull only.  It wouldn’t be an issue to make them cables.
WVHillbilly520H
TIA!
I just use the 1/8" diameter wire/rod from TSC/ Lowe's fairly cheap and simple. Not that cable wouldn't work but adding clamps and keeping them right and another snag point for clothing :eusa-think:... The xi series used cables from the factory
Edited by WVHillbilly520H
squonk
Drop ceiling grid wire. sold at Lowes an Home Cheapo.
Achto
Mine has a straitened out wire coat hanger on it. :hide:
  • Haha 3
squonk
Hope it isn't one of those plastic ones! :lol:
  • Haha 5
Ed Kennell
I have some old garage door lift cables that I use for this.  They all ready have a loop crimped in the one end that I put at the top handle.
 I use small eye bolts as guides and put a small turnbuckle in line to adjust the tension.
On my 520 with the cab, I modified the blade angle lever to a horizontal position inside the cab by my right leg.
The cable worked great for this as the lever has several bends to get inside the cab.
102_2586.JPG.c466495f072c7d629dcf960f6eb4e1c9.JPG102_2587.JPG.208291456c6fdeac5132aa7d031b2342.JPG102_2587.JPG.208291456c6fdeac5132aa7d031b2342.JPG102_2588.JPG.efde21524a14b8eab73975b43c1dac33.JPG
  • Like 5
  • Excellent 3
Horse Newbie
Shade tree !
  • Haha 2
Horse Newbie
What is the galvanized coupling... onboard waterworks ?:lol:
Ed Kennell
A 3/8 sch 40 pipe nipple just slides down over the motion lever.    Cut a notch to clear the bend  in the lever and screw on a coupling to lock it in place.  Gives me an attachment point for my foot pedal and pneumatic cylinder w/o altering the hand lever control.
