The Tuul Crib
40+ year old Gravley with seat attachment Update!
The Tuul Crib
On 2/5/2021 at 9:18 AM, squonk said:
Gravely's! Growing up my next door neighbor had an old  one out of the 50's Round mower deck and the Dog Eater snow blower. It would throw snow over the power wires! :banana-wrench: Guy across the street had the same set up. They both insisted on mowing their yards at the same time every Saturday while I was trying to watch cartoons! :angry-tappingfoot:
:text-yeahthat:
The Tuul Crib
Well last night I decided to take the top end off and do a carb dip. By the looks of the serial number date codes this was a replacement motor. It takes the motor to 1986. I'm thinking this machine is a little older than 1986?
The top of the piston was stamped FLY with an arrow towards the fly wheel an STD which we all know what that means!
he said something was done to it such as may be being bored out when he got it. Hope to get it back up and running soon. As soon as I figure out this transmission!
:confusion-confused:
The Tuul Crib
OK got the head back on it carburetors going to soak for another day or two.
i'm trying to gain knowledge on this machine is a go as to how it works. Friend of mine came over today looked at it and he knows how to run these machines.
so he says anyway. Trying to figure out what kind of oil to put in it. Plus I filled up the gas tank with vinegar and shake it every now and then for the next week or two.
squonk
Is that a 1 speed model? I don't see the Hi-lo shifter. I was given an old Gravely with a snowplow on it like 30 years ago. Only had 1 speed. forward was so fast you could hardly keep up with it and reverse practically ran you over. No electric start either. Love to have a nice one with the hi-lo and a snow cannon!
shallowwatersailor
I use to belong to this group when I owned Gravely tractors. They have manuals online which should help you. The 5260 is a two-speed tractor.
https://www.gtcoa.com/
squonk
Just curious John, Where is the Hi-lo shifter? I've always seen it right next to the forward/  reverse lever. I was thinking the LH lever in this pic would be the PTO lever.
Maybe the hi-lo lever is barely visible in this pic on the lower left ?
Edited by squonk
shallowwatersailor
Mike, I had a 5460 which was my favorite because with the 8 hp Kohler had a nice balance to it. The guy I sold it to has contacted a couple of times that he really enjoys it! Sort of wish that I hadn't sold it. The Direction Lever is on the right handlebar, the Hi-Low is on the left handlebar, and the PTO handle is on the dash just below where the handlebar is attached. It pushes in to disengage and pulls out to engage. For the 5460 the Range Shift (4-speed) would be also on the dash but on the right side.
John
The Tuul Crib
@shallowwatersailor thanks for that info that is a huge help for me! Although I will be selling this machine after I get it operating correctly!
:banana-dance:
seuadr
@The Tuul Crib Hey - what does the wires coming out from behind the flywheel look like on your machine? what color are they? do they have a connector that looks like this:
Also - do you have a glass fuse in line between your starter solenoid and the "B" terminal on your ignition? if so - can you tell me what amperage it is?
Edited by seuadr
The Tuul Crib
Ill take a look when l get home!
squonk
Throw that glass fuse holder away and get a blade fuse holder with a weatherproof cap.
ATC/ATO Fuse Holder up to a 40 Amp Fuse, 10 AWG Lead
The Tuul Crib
Sorry it took so long for me to get back but the connector I have is just like this one
in your picture.
seuadr
in your picture.
awesome! where does it go? :D
The Tuul Crib
Behind the flywheel. Can't imagine it would be but maybe three amps?
no lights and no cigarette lighter !:confusion-confused:
BTW do you know if this was an option to have these outside wheels added. The hub between the tires is cast-iron and I'm assuming it's maybe 10 ir 15 pounds?
Edited by The Tuul Crib
Oldskool
Mines a different model but 2 red from fly wheel plug, plugs to 2 blue to here.
seuadr
my engine is nowhere near my chassis - was the plug long enough for you? seems really short to me, but, like i said, i don't actually have them lined up.
seuadr
yep. spacers are just a bolt on:
Oldskool
My plug is close to the engine. With both connected there isnt much extra wire there.
