homegrownusa
Diff lock or steering brakes on 520h
homegrownusa
Has anybody tried to diy steering brakes or diff lock on a 520h or any wheel horse with similar transmission?
ebinmaine
@Greentored Scott...
pfrederi
D Series had steering brakes on a sunstrand hydro.  They were a disc mounted between the hub and the axle housing.  They were independent of the hydro unit so i wold guess you could adapt them to a Eaton or even an 8 spd
littleredrider
I’d like to try something like this. Dunno how many times get too far off driveway n get stuck. One wheel on snow/ice, the other on dry blacktop. If can find a disc to fit the bolt pattern, could use a go-cart caliper for the brake.
pfrederi
DennisThornton
I have both locking diff and steering brakes on my New Holland and I use them quite a bit.  I'd love to have both on all my working tractors!
gwest_ca
Have often thought about how to do it.
Changed the brake rotors on the wife's Camry. The rears are not vented and the bolt pattern is the same but have a drum on the inside for parking brake shoes. I think they would slip over the tractor hubs just like on the car. No doubt the OD would have to be reduced to get a go-kart caliper inside the wheel. Brake linkage to the left side is already there. Just need one straight back on the right and a pedal. Hardest part is likely coming up with a solid mount for the caliper.
Garry
ebinmaine
A sturdy bracket off the rear square area which could include the hitch would work well .. I think.
8ntruck
Sounds like a good place to start.
Is the thickness of the Camry discs comparable with the go cart calipers?  Would not be surprised if they would need to be thinner as well as smaller diameter.
ebinmaine
Perhaps you could bolt it to the INSIDE face of the wheel hub.
Use lug bolts to hold it.
953 nut
You don't have too much room to work with between the rims and the gas tank for turning brakes.    @stevasaurus, couldn't a limited slip differential from a late '60s or early '70s :wh: be used in an Eaton?
stevasaurus
@953 nut  I doubt that it would work in an Eaton, but I have not been in one.  Would a Wheel Horse transaxle bolt to the existing hrdro pump??  :dunno:
RandyLittrell
Garry
You could use studs instead of wheel bolts and bolt them to the backside of the hub to gain some room.
Randy
WVHillbilly520H
I thought the transaxles are ALL "UNI-DRIVE" whether manual or hydro??? and the PUMPS were either "Sundstrand" or "EATON" that powered the Transaxles.
pfrederi
The Transaxles for hydros are much simpler than gear obviously but there are differences between the transaxle housings used on the different hydros.  Even with Sunstrands different case housings were used between Hydro gear and piston to piston.
DennisThornton
This caught my attention:
No photo description available.
Obviously tracks but might work for wheels.
