homegrownusa 4 #1 Posted February 3, 2021 Has anybody tried to diy steering brakes or diff lock on a 520h or any wheel horse with similar transmission? Share this post Link to post Share on other sites
ebinmaine 68,887 #2 Posted February 3, 2021 @Greentored Scott... Share this post Link to post Share on other sites
pfrederi 18,004 #3 Posted February 3, 2021 D Series had steering brakes on a sunstrand hydro. They were a disc mounted between the hub and the axle housing. They were independent of the hydro unit so i wold guess you could adapt them to a Eaton or even an 8 spd 2 Share this post Link to post Share on other sites
littleredrider 409 #4 Posted February 3, 2021 I’d like to try something like this. Dunno how many times get too far off driveway n get stuck. One wheel on snow/ice, the other on dry blacktop. If can find a disc to fit the bolt pattern, could use a go-cart caliper for the brake. Share this post Link to post Share on other sites
DennisThornton 4,769 #6 Posted February 3, 2021 I have both locking diff and steering brakes on my New Holland and I use them quite a bit. I'd love to have both on all my working tractors! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,137 #7 Posted February 3, 2021 Have often thought about how to do it. Changed the brake rotors on the wife's Camry. The rears are not vented and the bolt pattern is the same but have a drum on the inside for parking brake shoes. I think they would slip over the tractor hubs just like on the car. No doubt the OD would have to be reduced to get a go-kart caliper inside the wheel. Brake linkage to the left side is already there. Just need one straight back on the right and a pedal. Hardest part is likely coming up with a solid mount for the caliper. Garry 2 Share this post Link to post Share on other sites
ebinmaine 68,887 #8 Posted February 3, 2021 1 hour ago, gwest_ca said: Hardest part is likely coming up with a solid mount for the caliper A sturdy bracket off the rear square area which could include the hitch would work well .. I think. Share this post Link to post Share on other sites
8ntruck 7,183 #9 Posted February 3, 2021 59 minutes ago, ebinmaine said: A sturdy bracket off the rear square area which could include the hitch would work well .. I think. Sounds like a good place to start. Is the thickness of the Camry discs comparable with the go cart calipers? Would not be surprised if they would need to be thinner as well as smaller diameter. 1 Share this post Link to post Share on other sites
ebinmaine 68,887 #10 Posted February 3, 2021 7 hours ago, gwest_ca said: go-kart caliper inside the wheel. Perhaps you could bolt it to the INSIDE face of the wheel hub. Use lug bolts to hold it. Share this post Link to post Share on other sites
953 nut 56,181 #11 Posted February 4, 2021 You don't have too much room to work with between the rims and the gas tank for turning brakes. @stevasaurus, couldn't a limited slip differential from a late '60s or early '70s be used in an Eaton? Share this post Link to post Share on other sites
stevasaurus 22,914 #12 Posted February 4, 2021 @953 nut I doubt that it would work in an Eaton, but I have not been in one. Would a Wheel Horse transaxle bolt to the existing hrdro pump?? 1 Share this post Link to post Share on other sites
RandyLittrell 3,885 #13 Posted February 9, 2021 On 2/3/2021 at 10:20 AM, gwest_ca said: Have often thought about how to do it. Changed the brake rotors on the wife's Camry. The rears are not vented and the bolt pattern is the same but have a drum on the inside for parking brake shoes. I think they would slip over the tractor hubs just like on the car. No doubt the OD would have to be reduced to get a go-kart caliper inside the wheel. Brake linkage to the left side is already there. Just need one straight back on the right and a pedal. Hardest part is likely coming up with a solid mount for the caliper. Garry You could use studs instead of wheel bolts and bolt them to the backside of the hub to gain some room. Randy 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #14 Posted February 12, 2021 On 2/4/2021 at 12:40 PM, stevasaurus said: @953 nut I doubt that it would work in an Eaton, but I have not been in one. Would a Wheel Horse transaxle bolt to the existing hrdro pump?? I thought the transaxles are ALL "UNI-DRIVE" whether manual or hydro??? and the PUMPS were either "Sundstrand" or "EATON" that powered the Transaxles. Share this post Link to post Share on other sites
pfrederi 18,004 #15 Posted February 12, 2021 3 hours ago, WVHillbilly520H said: I thought the transaxles are ALL "UNI-DRIVE" whether manual or hydro??? and the PUMPS were either "Sundstrand" or "EATON" that powered the Transaxles. The Transaxles for hydros are much simpler than gear obviously but there are differences between the transaxle housings used on the different hydros. Even with Sunstrands different case housings were used between Hydro gear and piston to piston. 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #16 Posted February 22, 2021 This caught my attention: Obviously tracks but might work for wheels. 1 1 Share this post Link to post Share on other sites
