Ed729 57 #1 Posted February 2, 2021 Hi all, Working on a restoration on my 312-8. It’s been in my family since new but has been outside for a few years and needs some work. I’m hoping to get things fixed and use it for yard work and getting firewood out of the woods. I’m sure I will have questions as I go. Thanks 6 2 Share this post Link to post Share on other sites
Ed729 57 #2 Posted February 2, 2021 Some pictures of where I’m at in the process. 2 6 Share this post Link to post Share on other sites
SylvanLakeWH 27,243 #3 Posted February 2, 2021 You're in the right place! 1 Share this post Link to post Share on other sites
rjg854 11,866 #4 Posted February 2, 2021 Ed, all the help you need is here, ask away. That's a good model as you probably already know. 1 Share this post Link to post Share on other sites
Ed Kennell 40,305 #5 Posted February 2, 2021 to the Ed. Looks like you're on your way to restoring a great tractor. 1 Share this post Link to post Share on other sites
8ntruck 7,336 #7 Posted February 2, 2021 Welcome to the forum. Whatever issue you run across on your tractor, chances are pretty good that somebody here has seen the problem and fixed it. 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #8 Posted February 2, 2021 On 2/2/2021 at 1:27 AM, Ed729 said: needs some work. I’m hoping to get things fixed on Looks like you are already deep in to the Restoration progress! Looks great! 1 Share this post Link to post Share on other sites
953 nut 57,581 #9 Posted February 2, 2021 On 2/2/2021 at 1:27 AM, Ed729 said: 312-8. It’s been in my family since new Always like to see a one family being shown some love. Hope you took lots of pictures as you disassembled the 312 so you know how it goes back together. If not we are here to help, ask any questions you might have and keep us updated as you go along. 2 Share this post Link to post Share on other sites
jay bee 912 #12 Posted February 2, 2021 to Looks like you jumped right in the deep end!!! 2 Share this post Link to post Share on other sites
Ed729 57 #14 Posted April 7, 2021 (edited) Edited April 7, 2021 by Ed729 Moved to restoration topic. Share this post Link to post Share on other sites
Volant1006 34 #15 Posted April 30, 2021 Welcome, great tractor. Love to see an old horse get new shoes! #NoHomeDepotTractors Share this post Link to post Share on other sites
AmishMenno 3 #16 Posted May 13, 2021 I'm new to this forum. I bought a nice 312-8 fall of 2020 and am very happy with it. I used it to haul chainsaw and bring wood out of the woods last fall. I installed the deck today and decided to mow grass. I like the way it cuts and will be using it more. I have a question: Does anyone know if a stainless steel exhaust pipe is available to connect to end of muffler so I can have an upright stack.? Maybe two feet or so? I would just be for looks. Oh, I need a replacement shock to hold seat up while filling the gas tank. Do you all advise to use leaded gas or unleaded in my Kohler engine? Thank You, 1 1 Share this post Link to post Share on other sites
WHX?? 50,560 #17 Posted May 13, 2021 (edited) Amish.... fine lookin steed ther and a worthy workin tractor. You'll haul alot of wood with her you treat her right. On the stack I have never done one with that type of muffler but be wary of what you wish for as stack exhausts and low hanging branches as working in the woods do not play well. Hopefully others will be along to offer advise and welcome. Edited May 13, 2021 by WHX24 Share this post Link to post Share on other sites
oliver2-44 10,274 #18 Posted May 13, 2021 We recommend you use ethanol free regular gas. 1 Share this post Link to post Share on other sites
AmishMenno 3 #19 Posted May 29, 2021 I put my mower deck on this week, as I was mowing the mower clutch would stop and the belt to the mower stop? When I engage the clutch lever the mower would begin running again. What do you think is the problem. Share this post Link to post Share on other sites
953 nut 57,581 #20 Posted May 29, 2021 You may just need to turn the PTO adjustment trunnion a bit to let the PTO lever go further over center. 1 Share this post Link to post Share on other sites
Ed Kennell 40,305 #21 Posted May 29, 2021 , But you should pull the pulley bell off and make sure the clutch plate and liner are OK. 1 Share this post Link to post Share on other sites
AmishMenno 3 #22 Posted May 30, 2021 On 5/29/2021 at 11:53 AM, 953 nut said: You may just need to turn the PTO adjustment trunnion a bit to let the PTO lever go further over center. 1 Share this post Link to post Share on other sites
AmishMenno 3 #23 Posted May 30, 2021 Thanks, I will check that. But? The mower ran full RPM the last time I had installed it and I did not make any adjustments. I just removed it and reinstalled it. Does the tension on the belt have any effect? I have tried tighter and looser but did not seem to make difference? It seems if the PTO is engaged the pulley should run the belts at proper speeds. Another dumb question I guess but what is the main function of the little adjustment for the tall lever letting the deck up and down? The grass height is set entirely by the lever on the deck. Right? Share this post Link to post Share on other sites
AmishMenno 3 #24 Posted May 30, 2021 On 5/29/2021 at 12:23 PM, Ed Kennell said: , But you should pull the pulley bell off and make sure the clutch plate and liner are OK. Thank you for suggestion. I don't know how to pull it off but will see if I can check that before mowing again. Share this post Link to post Share on other sites
Ed Kennell 40,305 #25 Posted May 30, 2021 On 5/30/2021 at 1:15 AM, AmishMenno said: I don't know how to pull it of Remove the pin that fastens the hoop to the end of the bell and swing the hoop to the rear. Loosen the mule drive and then remove the deck belt from the bell. Remove the brake pad bracket...two bolts. The bell will slide right off 1 Share this post Link to post Share on other sites
