wheelhorsejoe
Cab windshield Defroster
wheelhorsejoe
can a wheel horse 416-8 electrical system power a 150w defroster? The engine is a 16hp K-series engine. Thanks Joe
Edited by wheelhorsejoe
Handy Don
Onans have a 20 amp alternator (20amps @12v = 240w). Remember some is going to battery charging and to keep the plugs sparking and maybe lights?!
Edited by Handy Don
Maxwell-8
pff, that whould be the max i would wanne ask from it, headlights 60-70w, ignition system some, want to charge the battery,etc
and that 20 amps is in high rpm.
I reccomand installing a car or atv alternator
When you install an extra alternator:  welcome heated seat :D
Edited by Maxwell-8
gwest_ca
Kohler mostly likely has the 15 amp charging system so max = 180W.  (Volts x amps)
That is not leaving enough for lights, ignition and battery charging.
Garry
roadapples
Turn on defroster only when needed for a few minutes. Then turn off.
squonk
Also switch to LED Lamps to reduce wattage
  • Like 4
horseyheaven
I use two battery operated fans in the cab of my 520HC.  They work well for keeping my breath from fogging the windows up.  The ones I bought are able to clamp anywhere you want and can be swiveled\angled to hit in different areas.  I went this route because I did not think I would have enough charging system for a defroster.  I just searched battery operated fans on the internet.
