peter lena
flange bearing source
peter lena
 when replacing a bearing , problem area , always think of how to improve this spot , and possibly strengthen it . https://www.google.com/search?q=flange+bearings&sxsrf=ALeKk02J1QLze3MQxZ1IF9U7Uql4zfrZEA:1612186451000&tbm=isch&source=iu&ictx=1&fir=_HxG5j5y2JldcM%2Cra-jtBFu5hL4ZM%2C_&vet=1&usg=AI4_-kTWrIWx6yaSuXqfqKuCrcE9VECAQA&sa=X&ved=2ahUKEwj_wOTF5sjuAhWLjlkKHSSOA2EQ_h0wAXoECD0QBA&biw=1024&bih=625 , good selection and possible ideas for your issue. another thing I detail this with is , hi temp tacky grease , don't even hesitate to change out generic grease , that will fail . since using it , no noise ,and no failures . just my own experience , always trying to improve on a functional , movement point , good luck with your transition , pete
  • Like 4
peter lena
think this singular 3/4"  3 bolt mount , has got real possibilities to add to a difficult spot , https://bearingsdirect.com/mounted-block-bearings/3-bolt-bracket-flange-unit-bearings/34-bore-ucfb204-12-bracket-3-bolt-flange-unit-ball-bearing. thinking of an unsupported shaft or bracket , that needs support . really a good spot to just look at and say , " what if put ... ,  that's what I regularly do to improve what ever I look at , pete
