Wheel Horse 3D
Custom 3d printed badges, ornaments etc.
cafoose
Sorry one of the pictures was blurry so I edited it :hide:
Wheel Horse 3D
4 hours ago, cafoose said:
Man i think that would have to be at least a 4 part deal with the printers I have. Biggest dimension I have is about 11.75
cafoose
If you think it's doable and it will work I'd say go for it :banana-wrench:
Wheel Horse 3D
Is there any dimension under 12"?
If that's the case, I could make stackable rings. If not it will have to be quartered at least.
cafoose
As long as it holds gas and doesn't leak anything you can do will be good. @19richie66 is getting dimensions.Maybe that would help?
Wheel Horse 3D
Have been thinking on the next printer to purchase. Whether to upgrade size, or to go with another speedy Bambu.
Might have to think more in size ! Lol
Wheel Horse 3D
If they were fabricating them they'd have everything I'd need to model with!
Wheel Horse 3D
Just finished up this project! Pretty proud of it. 4tpi well pipe to 8tpi well pipe adapters. Original on the left, draft center, and final done in a higher temp chemical resistant filament at full density. Thread design worked out well with a couple drafts to get the female sizing just right.
  • Like 5
ebinmaine
I've never messed with a well.
What's the purpose of you building those as compared to buying them?
Not available?
Pricey?
You felt like it?
wallfish
Not available?
Pricey?
You felt like it?
I asked Grey if he could 3D me some specialty pipe adapter parts. They are not available off the shelf.
He took on the challenge with doing the threaded parts and knocked them out very quickly. Impressive and done at a fair price.
  • Excellent 2
ebinmaine
NIIIIICE
Wheel Horse 3D
Another @wallfish custom part!
Wheel Horse 3D
Just received a GT14 tank from @cafoose
To see if we can get a suitable replacement printed.
  • Excellent 3
Wheel Horse 3D
Another use for the printers!.....custom leather embossing! Just a quick test on the click press...some really interesting stuff
Edited by Wheel Horse 3D
  • Excellent 3
Wheel Horse 3D
Preliminary GT14 gas tank model!
  • Heart 2
Wheel Horse 3D
Filler neck modeled!
  • Excellent 3
Wheel Horse 3D
Slammed with tombstone orders! Each heavy duty set takes over 48 hours to print and 2 full spools of filament. Had to order in more red!
  • Excellent 2
ebinmaine
Excellent!!!
Wheel Horse 3D
Confirmed tombstone handle on one half of the heavy duty version can handle at least 25 lbs!
  • Excellent 3
Wheel Horse 3D
Tank parts split up for print.
Wheel Horse 3D
Each half will be 4 DAYS of printing and 1.5 spools of filament! Gonna have to find some inexpensive filament to keep cost down.
oliver2-44
On the GT14 gas tank are you printing them with the original bottom outlet nipple, or are you putting a heavy boss at the bottom for a rubber gas bushing ?
Wheel Horse 3D
If ya look closely, there's an outlet right hand bottom. I was figuring ya could tap and insert a brass fitting, perhaps a 90 degree 3/8 or 1/4 NPT hose barb?
Wheel Horse 3D
The tanks will still have some DIY to do.
Epoxy and seal the 2 halves together, maybe do a coat of gas tank sealer, and add your outlet fitting.
Next to do is design the cap and be sure to incorporate the vent hole.
oliver2-44
@Wheel Horse 3D If these tanks work out,  the tanks for the WH Suburbans and RJ’s should be next on your list.  Used ones are selling for over $100 on Evil Bay and are usually so rusty you have to seal them. The Suburban and RJ tank are the same size and shape, but inlet and outlet are in slightly different locations. Also they are a lot smaller,   I’ll try to find some pictures.
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
