snowhound
310-8 and older snow plow
snowhound
I want to put and older snow plow on a 310-8 and need a newer style lever to angle the blade.  SLE Equipment has what I need has anyone done business with them and would you do business with them again?
953 nut
I have no information about SLE Eq. but the blade angle lever is easy enough to build.  :confusion-scratchheadyellow:   Have you considered making your own?
stevasaurus
When you say..."older blade" do you mean the "A" frame type?  If so, you may find that when mounted you may not be able to angle the blade because it will hit the front tires.
older type
newer type
snowhound
It's like the second photo and clears the tires when angled but the arm to angle the blade doesn't clear the muffler.  I believe I need one of the arms that has two 90 degree bends and uses a cable to pull the pin to angle the blade
953 nut
I just sent you a PM with pictures of the later model arm.
WVHillbilly520H
I have and they were fine to deal with, now that being said we can't count on shipping times these days...
Richard the angle from seat lever he insist likely referring to has multiple bends in it to clear the muffler and foot rest... Not too easy to home fab without a pattern and a few tools.
snowhound
do you have a part number?
Horse Newbie
Does anybody know if Lowell (@Wherlhorseman) makes them ?
I know I got one from him for my 520H.
