F. Marra 17
414-8 transmission leak
F. Marra 17
I have a late 80's 414-8. my transmission has a slow oil leak. it leaks slow so its hard to see where it is coming from. i get a small puddle/stain on the floor center under the trans after a few days of non-use.  is there a usual problem area that leaks? or is there anyone in the NJ area that can be recommended to repair the trans? I am sure due to its age that gaskets or seals may be shot.  the tractor sat for 10+ years at my office on a shelf.  It has ran well the past 3 years for me.  I would like to fix this leak if possible.  Any advice or help is greatly appreciated.
THANK YOU,
Frank
Pullstart
Hey Frank,
the 8 speed doesn’t have too many leak points.  Input shaft, brake shaft, axle shafts and case gasket.  The gear shifter has a boot and the hi-low shifter has nothing.  Not too much fluid gets tossed that high to leak out.
My best suggestion would be to wash the transmission well with a degreaser and or a pressure washer.  Put some masking tape under the shafts mentioned and near the case gasket.  Run it a while, check the tape for moisture.  That should indicate where it’s coming from.  The key is to not let the leak point to saturate everything before you check.
  • Like 5
SylvanLakeWH
:text-yeahthat:
Short term suggestion - cardboard underneath keeps the floor clean...
daveoman1966
Retorque the 5 or 6 bolts that hold the Trans Cases together.  MAYBE an easy fix.
  • Like 3
Pullstart
Wow, great thought!
squonk
I bet it's either the brake shaft or input shaft. Tractor sat for a while, seals hardened. Now running the brake and input shafts spin pretty fast. Prolly tore the seals. My 953 started pissing like a racehorse and left a puddle right in the middle underneath the case. Input seal was almost non existent.
Edited by squonk
F. Marra 17
Thanks for the suggestions, I have some old carpet underneath for now, and have torqued the bolts in the past.  ill try the tape method to get a better idea.  i'm using the tractor to snowblow right now so i don't want to go too crazy disassembling until the winter is over.
Pullstart
Keeping a little extra fluid in it won’t hurt anything either, better to have extra than not enough!
  • Similar Content
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • nylyon
      By nylyon-(Admin)
      I think I am selling my 1987 414-8 with plow, weights and chains.  Now here’s the story on this one. A long long time ago, I was searching for a snow plow for my 416H.  In that search I stumbled onto a forum which was one day old.  There was no name of the forum, just whtractor.15.forumer.com. Trying to learn more about snow plows I started conversations with one of the active members on the site, let’s call him Mike.  Mike convinced me I didn’t need a plow, but an entirely new tractor.
      About a week or so later, I found this 414–8 for sale, and bought it.  I now had my plow and could plow the driveway. So what happened with Mike @Sparky and this forum I spoke of? It grew a little bit, and we now call it RedSquare, and for sale is one of if not THE reason RedSquare exists today, so you can own a piece of RedSquare history!
      About the tractor: 1987 414-8. Kohler M14, runs well does not burn oil. Everything on the tractor works as it should, but it is a worker. The plow is a 48” with a custom made scraper blade, made from heavier stock than original. For the past several years, this has been a dedicated plow tractor, so it hasn’t seen a lot of work, but has also sat outside (under a tractor cover) so lots of let’s say, patina going on.
      I a, selling because I just picked up a 416-8, and that will become my winter plow / blower tractor.  I am looking for $550, but like I said this tractor is a bit of a legend!
      I have cleaned it up since the pictures were taken.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
