ebinmaine
How can I put a 120° bend in 3/4" diameter rod?
DennisThornton
8 minutes ago, wallfish said:
Yeah, put a rose bud head on them and it's about like striking a match. That's all I have and it does the job. You can also get just the tanks to have spares on hand which gives some time to get to the gas store for a swap.
Beats the crap out of Map only or even the little Map/O2 sets!  Great for smaller stuff.  The torch supplied is small because the tanks just won't last long with a bigger torch.  But still!  Heat, braze, weld and cut!   Can't weld with a propane setup.  And brazing with acet/O2 is much easier and quicker too!  Quick is handy when you want to get on and get off before overheating things that don't appreciate heat.
I love mine for small and portable tasks.
Lee1977
3 hours ago, wallfish said:
Depending on your tools, Is it easier to bend the 3/4 rods or drill a 3/4 hole?
Maybe something like this to weld a 3/4 rod into. :dunno: Might be stronger too. $20 from Northern tool but may find them less expensive somewhere else
:twocents-02cents:
Have a 30 degree milled of the top of the square section and a 3/4" hole drilled predoctoral to that angle and weld it on the bottom.
  • Excellent 2
  • Thanks 1
DennisThornton
If I didn't have my Oxy/Acet torches I would either use my coal forge or I'd break down and build that propane forge that I've intend to build for years.  I really think that is today's answer to heating and working metal if it's more than one piece at a time.  Most everything it need is just a single heat but if I had a project I'd change my ways and build a small propane tank propane forge.
roadapples
NAPA used to sell basically  the same thing only with mapp gas about 40 years ago. $300. Couldn't  justify  that at the time. Couple  years  later  picked up one at a yard sale for $25. Still have it. Exchange  oxygen  tank when needed...
Like the small set wallfish showed..
Edited by roadapples
Jeff-C175
8 hours ago, wallfish said:
Adding a little bit of oxygen
I learned that the O2 tanks on that setup don't last but maybe 10-15 minutes so that could get costly for a longer time use.
DennisThornton
Yep!  But you could be a magician for 10-15 minutes!  Or a costly failure...
Been there for both...
gt14rider
Spindles off gt14, 3/4" spindles, press in, then weld.
  • Like 4
  • Excellent 1
ebinmaine
I can do the drilling here.
Why the 30° angle?
To hit "square" from the drilled face?
That would be ok because I have to weld on the steering arm above it.
The steering arm would be 90° to the vertical shaft.
953 nut
You could use a shaft collar to give you a 90° angle and clamp the steering arm to it for welding.
  • Thanks 1
oilwell1415
I was going to suggest using the stub axles as well.  If that's a no go, I've had good luck with the method below.  Block 1 and the mandrel are fixed to the table.  The two blocks start off lined up next to each other, but block 2 is connected to a pivot at the center of the mandrel by an arm and rotates around the mandrel as you make the bend.  You would connect any lever needed to block 2 to prevent bending the spindle anywhere except where you wanted it bent.
gt14rider
Here are more pics of spindle, looks to be 82 deg
WVHillbilly520H
Lee, what is predoctoral? Even playing machinist for 14+ years never heard that. Did you mean perpendicular?
Lee1977
yes
  • Thanks 1
WVHillbilly520H
5 minutes ago, Lee1977 said:
yes
Ok, I wasn't sure, I hear new terms everyday.
  • Excellent 1
WVHillbilly520H
@ebinmaine, Eric this just hit me how about a heavy duty conduit/pipe bender ???
ebinmaine
That would be a way if it would make a really sharp bend.
WVHillbilly520H
You can make 90°+ on 1" conduits I know from experience, solid bar I can't say.
Oldskool
So where do you stand on this?
WVHillbilly520H
My opinion or the tool?
Oldskool
Either one. I know I have tried using one of those and couldnt get a very tight bend.
WVHillbilly520H
With conduit it did okay, the radius is dictated by the tool.
Oldskool
Do those benders have different radiuses?
71_Bronco
I always thought those had the longer / larger radius to allow wires to fee through easier, and so the pipe wouldn't crush / kink.
Not sure they would be good for a super tight bend, but I could be wrong.
On a side note, I assume making a welded "miter" style bend is not an option? Not sure how strong that would be vs a single bent piece.
Oldskool
@ebinmaine I sent you a message did it not go thru??
WVHillbilly520H
We had 2 or 3 at the last place I worked they were all different , no not super tight radius. A 90° bend angle is just that ,but what is the radius on the factory spindles 1.5" ?
