Gregor 4,847 #1 Posted January 24, 2021 This is a push nut. Obviously. It is for round stock. Where can a guy find push nuts for square stock? They are used to hold coil assemblies on to the laminate section of a magneto assembly. I have looked at Grainger, McMaster Carr, Amazon. Nothing yet. Thanks Greg Share this post Link to post Share on other sites
ebinmaine 70,801 #2 Posted January 24, 2021 Not something I've ever had to look for. The only other place I could think of would be KL Jack. Share this post Link to post Share on other sites
8ntruck 7,395 #3 Posted January 24, 2021 (edited) Fasenall stocks a selection of special automotive fasteners. maybe you could fimd something there? Edited January 24, 2021 by 8ntruck Share this post Link to post Share on other sites
Daddy Don 907 #4 Posted January 25, 2021 I have only used this type on round stock. Never have tried it on any other type of metal stock. Share this post Link to post Share on other sites
Gregor 4,847 #5 Posted January 25, 2021 Can anyone think of another way to secure the coils onto the laminate? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,252 #6 Posted January 25, 2021 A bead of urethane caulking around the end. I get it at Home Depot and use it up after as it has a short shelf life after opened. They have it in white gray and black. Garry 1 Share this post Link to post Share on other sites
oliver2-44 10,371 #7 Posted January 25, 2021 Try a round push nut that will tightly fit the square stock. 1 Share this post Link to post Share on other sites
Gregor 4,847 #8 Posted January 25, 2021 Thought about that, but I would sure hate for it to fail, and come lose inside the flywheel. I Might have to see what's available. Thanks Share this post Link to post Share on other sites
formariz 11,994 #9 Posted January 25, 2021 1 hour ago, Gregor said: Thought about that, but I would sure hate for it to fail, and come lose inside the flywheel. I Might have to see what's available. Thanks What I have done in the past a few times was to take the closest size one and removed or bent the 2,5,8,and 11 O'clock tabs. In that kind of application with no sideways force being applied it holds more than sufficiently. Just do one and then try to remove it. You will see how tough it is. Share this post Link to post Share on other sites
Gregor 4,847 #10 Posted January 25, 2021 (edited) My local store didn't have anything large enough. I guess I will have to order something. Hmmm Don't know what I did to my font. Edited January 25, 2021 by Gregor Share this post Link to post Share on other sites
John2189 503 #11 Posted January 25, 2021 How about glueing it on with rtv silicone? That stuff holds really well Share this post Link to post Share on other sites
Gregor 4,847 #12 Posted January 25, 2021 23 minutes ago, John2189 said: How about glueing it on with rtv silicone? That stuff holds really well I know., and if my plan doesn't work, I want to be able to take it off. Share this post Link to post Share on other sites
WHNJ701 4,165 #13 Posted January 25, 2021 Can't you just make it? What's is it the clip on pull start kohler coil? Share this post Link to post Share on other sites
Gregor 4,847 #14 Posted January 25, 2021 Tecumseh spring material Share this post Link to post Share on other sites
Gregor 4,847 #15 Posted January 29, 2021 (edited) I ordered some 1/2" round push nuts from McMaster-Carr. I think they will work fine. Of course I had to order 100 of them, so if anyone needs some............ But you had better hurry, in 2 days I won't know where they are. Edited January 29, 2021 by Gregor Share this post Link to post Share on other sites
