Jim Turner 42 #1 Posted January 21, 2021 Has anyone added hydraulics to a Raider 14? I am liking the Raider 12 or 14 to use in the garden pulling a tiller or other implements but would really appreciate if I could add Hydraulics to it. but I don't really want to use the PTO to run a hydraulic pump. I could use a 953 i guess but I does not have not seen anyone mount a tiller on the back that does not require its own engine. I bet someome on here has figured out how to mount a rear tiller on their 953/1054 or hydraulics on their gear shift wheel horse. 1 Share this post Link to post Share on other sites
ebinmaine 70,390 #2 Posted January 21, 2021 @Achto 1 Share this post Link to post Share on other sites
Achto 28,615 #3 Posted January 21, 2021 24 minutes ago, Jim Turner said: Has anyone added hydraulics to a Raider 14? I added a Hien Werner pump to my Raider 12. Unlike the pumps that they made for the tractors, my pump turns clock wise and had to be driven from the flywheel side. 6 1 Share this post Link to post Share on other sites
Pullstart 64,388 #4 Posted January 21, 2021 @953 nut? Is there a tiller setup for 953 / 1054’s? Share this post Link to post Share on other sites
Jim Turner 42 #5 Posted January 21, 2021 15 minutes ago, pullstart said: @953 nut? Is there a tiller setup for 953 / 1054’s? I am looking for a tiller and linkage that can allow it to be run off the tractor PTO and not a separate motor. Share this post Link to post Share on other sites
Jim Turner 42 #6 Posted January 21, 2021 19 minutes ago, Achto said: I love it. that looks great.. I had a feeling the best way to add hydraulics would of been off that side of the engine. great job. and thanks for the responce. 1 1 Share this post Link to post Share on other sites
Handy Don 13,266 #7 Posted January 21, 2021 23 minutes ago, Achto said: I added a Hien Werner pump to my Raider 12. Unlike the pumps that they made for the tractors, my pump turns clock wise and had to be driven from the flywheel side. @Achto, I see you've connected the pump to a "standard" WH cylinder/rockshaft. How did you calculate the capacity/limits of that system to choose the pump? I've often wondered if the Eaton 1100 charge pump could handle a second cylinder mounted somewhere else on the tractor (with separate controls, of course). Is there a way to determine this? Also, do you (or does anyone) know what are the actual lift capacities of the WH systems? I know the later 520-H's system could lift the 60" deck and I understand that is 300+ lbs. Share this post Link to post Share on other sites
Pullstart 64,388 #8 Posted January 21, 2021 (edited) @Handy Don my guess is Dan whipped out his eyecrometer and said “yep, that aughtta work!” And tossed it on. Edited January 21, 2021 by pullstart 1 2 Share this post Link to post Share on other sites
Achto 28,615 #9 Posted January 21, 2021 (edited) 22 minutes ago, Handy Don said: I see you've connected the pump to a "standard" WH cylinder/rockshaft. How did you calculate the capacity/limits of that system to choose the pump? 15 minutes ago, pullstart said: my guess is Dan whipped out his eyecrometer and said “yep, that aughtta work!” And tossed it on. Yep! It was more of a "fly by the seat of your pants". The add on HY pumps ran the lift cylinder in about the same place as I have mine mounted. I figured if it work as a factory add on, that it should work the way I have it also. It lifts my moldboard plow, and so far every other implement that I have attached to it. As far as lift limits - I have calculated that when I find something that the hydraulics won't pick up, then that item is too heavy. Truthfully, I think that the small cable running to the slot hitch would be more of a limitation than the Hien Werner setup. Edited January 21, 2021 by Achto 2 Share this post Link to post Share on other sites
Handy Don 13,266 #11 Posted January 21, 2021 9 minutes ago, Achto said: As far as lift limits - I have calculated that when I find something that the hydraulics won't pick up, then that item is too heavy. You and @pullstart oughta form an act together FWIW, my rough calc on the travel geometry of the cylinder throw (~4") and the lower lift arm at the lift pin (~6") and a 325 lbs. deck means the cylinder force must be at least 450 lbs. I read somewhere that the charge pump should put out 700 psi so this makes sense if the piston has a bit less than 1 sq inch of surface. 2 Share this post Link to post Share on other sites
Pullstart 64,388 #12 Posted January 21, 2021 15 minutes ago, Handy Don said: You and @pullstart oughta form an act together FWIW, my rough calc on the travel geometry of the cylinder throw (~4") and the lower lift arm at the lift pin (~6") and a 325 lbs. deck means the cylinder force must be at least 450 lbs. I read somewhere that the charge pump should put out 700 psi so this makes sense if the piston has a bit less than 1 sq inch of surface. Our act gets better, when Uncle Jim’s in the wheelchair! 2 4 1 Share this post Link to post Share on other sites
pfrederi 18,289 #13 Posted January 21, 2021 The sunstrand hydros can handle two lift cylinders as on a D series with 3pt. Have operated both at once but with out any load on the midmount. Just a bit slower. 4 2 Share this post Link to post Share on other sites
Goldnboy 978 #14 Posted January 21, 2021 (edited) I have done a similar conversion of adding dual hydraulics to a B80-8 now with a K321 from @richmondred. There is a build thread that I created last winter on this. Edited January 21, 2021 by Goldnboy 2 3 Share this post Link to post Share on other sites
953 nut 57,581 #15 Posted January 22, 2021 7 hours ago, pullstart said: @953 nut? Is there a tiller setup for 953 / 1054’s? To my knowledge there wasn't a tiller for the 953/1054 but there is no reason a tiller from a later model couldn't be used with some slight modifications. Tillers are best mounted to a six speed/eight speed tractor and I'm not too sure a 953 in first gear would be slow enough for good tilling. 3 Share this post Link to post Share on other sites
Pullstart 64,388 #16 Posted January 22, 2021 15 minutes ago, 953 nut said: To my knowledge there wasn't a tiller for the 953/1054 but there is no reason a tiller from a later model couldn't be used with some slight modifications. Tillers are best mounted to a six speed/eight speed tractor and I'm not too sure a 953 in first gear would be slow enough for good tilling. I know a guy with a low range in a 953 1 1 Share this post Link to post Share on other sites
953 nut 57,581 #17 Posted January 22, 2021 3 minutes ago, pullstart said: I know a guy with a low range in a 953 Doesn't take a great deal of talent to do that swap, even an old cave man like me can do it.. 2 Share this post Link to post Share on other sites
DennisThornton 4,771 #18 Posted January 22, 2021 27 minutes ago, 953 nut said: To my knowledge there wasn't a tiller for the 953/1054 but there is no reason a tiller from a later model couldn't be used with some slight modifications. Tillers are best mounted to a six speed/eight speed tractor and I'm not too sure a 953 in first gear would be slow enough for good tilling. I owned a 953 for less than one day. How many speed trans? Share this post Link to post Share on other sites
Pullstart 64,388 #19 Posted January 22, 2021 30 minutes ago, DennisThornton said: I owned a 953 for less than one day. How many speed trans? They are all 3 speeds, unless a 6 or 8 speed gets swapped in. I bought “Hot Wheels“ from Richard so I figured I could joke about that with him. Share this post Link to post Share on other sites
DennisThornton 4,771 #20 Posted January 22, 2021 How odd! First that I didn't know (or forgot...) Second that the biggest bestest only had a 3 spd. OK, I have a couple older WH rollers that I've never used but all my runners have Hi/Lo or hydro. When did WH come out with the Hi/Lo? Share this post Link to post Share on other sites
Pullstart 64,388 #21 Posted January 22, 2021 15 minutes ago, DennisThornton said: How odd! First that I didn't know (or forgot...) Second that the biggest bestest only had a 3 spd. OK, I have a couple older WH rollers that I've never used but all my runners have Hi/Lo or hydro. When did WH come out with the Hi/Lo? The 953 / 1054 has a special transmission too. Because of the hydraulics inside the frame, the bolt pattern is not your standard square 4 bolt. It’s an odd shaped 4 bolt. The differential is also beveled spider gears like an automotive diff and is known to be not quite as durable as the round pinion diff. I THINK ‘64 started offering hi/low range. Some 854’s were optioned with low range if I recall. Share this post Link to post Share on other sites
DennisThornton 4,771 #22 Posted January 22, 2021 2 minutes ago, pullstart said: The 953 / 1054 has a special transmission too. Because of the hydraulics inside the frame, the bolt pattern is not your standard square 4 bolt. It’s an odd shaped 4 bolt. The differential is also beveled spider gears like an automotive diff and is known to be not quite as durable as the round pinion diff. I THINK ‘64 started offering hi/low range. Some 854’s were optioned with low range if I recall. Thanks buddy! 1 Share this post Link to post Share on other sites
