Maxwell-8 4,366 #26 Posted January 20, 2021 18 minutes ago, ebinmaine said: Don't let that fool you. Some of Toro's part numbers are only 4 digits long because they go back so far. Like the 3577 dust covers on the trans 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #27 Posted January 20, 2021 10 minutes ago, bcgold said: AAiii hope to avoid that. 1 Share this post Link to post Share on other sites
ebinmaine 69,874 #28 Posted January 20, 2021 Just now, Maxwell-8 said: number At the top of the transmission section there is a bearing in seal cross reference that will give you at least a couple part numbers for different manufacturers such as Toro, SKF, National, whatever. Share this post Link to post Share on other sites
ebinmaine 69,874 #29 Posted January 20, 2021 I'm pretty confident that given enough patience and time and appropriate tooling such as a small Dremel as a grinder your hub will come off. Even if it's welded on both sides, there are some interesting shaped bits for the little Dremel grinders that you can get a hold of. 2 Share this post Link to post Share on other sites
Maxwell-8 4,366 #30 Posted January 20, 2021 1 minute ago, ebinmaine said: SKF We can get SKF seals! Hard to find but possible. thanks Again. 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #31 Posted January 20, 2021 Just now, ebinmaine said: I'm pretty confident that given enough patience and time and appropriate tooling such as a small Dremel as a grinder your hub will come off. Even if it's welded on both sides, there are some interesting shaped bits for the little Dremel grinders that you can get a hold of. Like their cutting discs that come flying around your ears hahaha. They have quite some nice stuff. I will try to get them off tomorrow, Pics and maybe a video will be up tomorrow! 1 Share this post Link to post Share on other sites
bc.gold 3,403 #32 Posted January 20, 2021 6 minutes ago, Maxwell-8 said: We don't have those places here, and the dealers are doing difficult, went by there today and they need a number, they couldn't find the number on their computer Yellow pages, bearing supply. Share this post Link to post Share on other sites
stevasaurus 22,973 #33 Posted January 20, 2021 Maxwell, the # 100863 is the new Wheel Horse part number for that seal. It equates to SKF # 9815. 1 2 1 Share this post Link to post Share on other sites
bc.gold 3,403 #34 Posted January 20, 2021 12 minutes ago, Maxwell-8 said: AAiii hope to avoid that. Removing welded hub topic posted, May 11/2020 1 1 Share this post Link to post Share on other sites
ebinmaine 69,874 #35 Posted January 20, 2021 14 minutes ago, Maxwell-8 said: cutting discs that come flying around your ears I do try to avoid that. Be sure to wear a full suit of pillows top to bottom. 1 Share this post Link to post Share on other sites
ebinmaine 69,874 #36 Posted January 20, 2021 13 minutes ago, stevasaurus said: Maxwell, the # 100863 is the new Wheel Horse part number for that seal. It equates to SKF # 9815. You're alright Steve. Maxwell take that SKF number to any parts store. Shouldn't be too hard to get because Wheelhorse used mostly "Standard parts". 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #37 Posted January 20, 2021 1 hour ago, ebinmaine said: The plug on the lower left side won't actually allow enough fluid to sit The raider was filled that way, and that may explain the metal shavings Share this post Link to post Share on other sites
Skipper 1,789 #38 Posted January 20, 2021 On the welded hubs part of it. A metal burr might be able to dig the weld out, if it is on the outside, which I would guess it is. Cutting the seals and hoping for them to not leak, might be a wishful hope. Wouldn't count on it holding up. I do if all goes wrong, have both 1" and 1 1/8" trannys and parts on stock, and seals for 1-1/8", but the 1" seals is not on stock until may. 2 2 Share this post Link to post Share on other sites
ebinmaine 69,874 #39 Posted January 20, 2021 12 minutes ago, Skipper said: 1" seals How long does it take to get things from here? 2 Share this post Link to post Share on other sites
Skipper 1,789 #40 Posted January 21, 2021 (edited) Not that long if you send direct, but to keep freight and import fees realistic, it goes in a container and hitches a ride that way, alongside a bunch of tractors and implements and what other things people want brought over. Only way to keep it realistic. Taxes we have to pay, but the fees are killing it on these small shipments. Edited January 21, 2021 by Skipper 2 Share this post Link to post Share on other sites
Greentored 3,217 #41 Posted January 21, 2021 17 hours ago, ebinmaine said: @Greentored Scott has been tossing around the idea of making these. I absolutely plan to start making hubs, as they do seem to be getting harder to find, especially in good shape without keyways beat all to crap. Id like to see how those hub centers would hold up- a 'slice' of steel disc could be welded to those and bolt pattern drilled. Im also not against making them out of one solid piece and purchasing a broach.... 2 Share this post Link to post Share on other sites
ebinmaine 69,874 #42 Posted January 21, 2021 5 minutes ago, Greentored said: I absolutely plan to start making hubs, as they do seem to be getting harder to find, especially in good shape without keyways beat all to crap. Id like to see how those hub centers would hold up- a 'slice' of steel disc could be welded to those and bolt pattern drilled. Im also not against making them out of one solid piece and purchasing a broach.... I'm certainly no expert at purchasing steel. Seems to me it would be less expensive to purchase the hub piece and the flange pieces separately then weld the 3 together. But of course there's a welding cost there that would not be involved if one single piece was the beginning. Share this post Link to post Share on other sites
Greentored 3,217 #43 Posted January 21, 2021 8 minutes ago, ebinmaine said: I'm certainly no expert at purchasing steel. Seems to me it would be less expensive to purchase the hub piece and the flange pieces separately then weld the 3 together. But of course there's a welding cost there that would not be involved if one single piece was the beginning. Agreed. As long as those steel 'hubs' are thick enough to hold up and not split. Machining a one piece hub would be awesome, but the time required....ugh. 1 Share this post Link to post Share on other sites
bc.gold 3,403 #44 Posted January 21, 2021 (edited) 4 hours ago, Greentored said: Agreed. As long as those steel 'hubs' are thick enough to hold up and not split. Machining a one piece hub would be awesome, but the time required....ugh. Cast iron is brittle while steel is malleable. With a pattern, I could cast that hub as a one piece part. I own the same induction furnace and it will melt 10 pounds of metal in less than five minutes. Edited January 21, 2021 by bcgold 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #45 Posted January 21, 2021 Men, those freaking hubs, they are welded bad, but with deep penetration, My opinion: axle and hub SHOT. After the 2100w Angle grinder: ON pics, it looks like it might work but in person, no 2 Share this post Link to post Share on other sites
bc.gold 3,403 #46 Posted January 21, 2021 (edited) 1 hour ago, Maxwell-8 said: Men, those freaking hubs, they are welded bad, but with deep penetration, My opinion: axle and hub SHOT. After the 2100w Angle grinder: ON pics, it looks like it might work but in person, no When you figure the weld has been ground thin, push the hub further onto the axle. Cast iron does not weld very good and the remaining weld should break free then you can clean up the axle to remove the hub. When you have the time can you give me the measurement of the piece that fits inside the wheel rim center also the bolt circle would be handy to know as well, thanks. Edited January 21, 2021 by bcgold 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #47 Posted January 22, 2021 https://www.partstree.com/parts/toro-100863/ This is for 1" diameter axles. 9815 is the SKF/CR number http://www.skfextranet.com/Catalogs/457010/sealdetail.asp?s=9815 Garry 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #48 Posted January 22, 2021 On 1/21/2021 at 8:24 PM, bcgold said: When you figure the weld has been ground thin, push the hub further onto the axle. Cast iron does not weld very good and the remaining weld should break free then you can clean up the axle to remove the hub. When you have the time can you give me the measurement of the piece that fits inside the wheel rim center also the bolt circle would be handy to know as well, thanks. Coming tomorrow! Share this post Link to post Share on other sites
stevasaurus 22,973 #49 Posted January 22, 2021 Maxwell, you've got nothing to lose. Grind the weld down to the end of the axle and maybe a touch more. The weld should break loose then..maybe with a little heat. 2 Share this post Link to post Share on other sites
Maxwell-8 4,366 #50 Posted January 27, 2021 (edited) On 1/22/2021 at 8:28 PM, stevasaurus said: Maxwell, you've got nothing to lose. Grind the weld down to the end of the axle and maybe a touch more. The weld should break loose then..maybe with a little heat. time to try it tomorrow, got a spare trans, so indeed nothing to loose. Made myself a nice hub puller from a thick steel plate And another small question: Can the outer axle bearing be replaced without splitting the case? Bought spare, replaced the seals only to find out, it didn't had axle bearing on the right axle and moved a bit up and down. It did had one on the left side. Thanks!!!! Edited January 27, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
