71_Bronco
Steering Bushing
71_Bronco
When working on my Lawn Ranger this weekend, I noticed the plastic bushing in the gas tank was shot (part number 1539).
What's the purpose of this bushing to be plastic? Can I swap with a bronze one of the same size? Or is that not a great idea?
I also noticed that when the gas tank is on, there is a bit of up-and-down play in the steering shaft (but the teeth still engage the fan gear). There is a stop collar on the shaft to make sure the shaft doesn't come all the way out, but it's almost like it's lower than it should be.
Would it be a good idea to add a spacer or washers between the collar and gas tank? To minimize the up-and-down play?
Thanks!
Handy Don
Thanks!
Yes on minimizing play.
On my horses, the stop collar has a grub screw that lets you re-position it properly. Some other models had a cotter pin and used a set of shim washers to do the adjusting.
Achto
:text-yeahthat: A brass bushing will work just fine to replace the plastic one. This is what I do with all of my tractors.
