WVHillbilly520H
My other Red tractor
WVHillbilly520H
8 hours ago, 23 Reo said:
That's a lot of snow. I guess I don't know a darn thing abut Virginia.
March 1993 snow drift in West Virginia.
  • Like 3
WVHillbilly520H
Finished up phase 2 and 3 of the snow warrior tools, finally drug the blower off the trailer and uncrated and final assembly then unboxed the cab, assembled and installed in will say this cab is ten times easier to install than the :wh: cabs and 100% more visibility plus way more room to move around in doors use zippers instead of hinges and latches and I put it on with little effort by myself. The snow blower is belt (like a roots type GMC blower) driven from the PTO shaft to the impeller gearbox is is very quiet during operation, has 3 sections of driveshaft from the tractor transmission to the sub frame then to the snow blower. Then put the rear blade on for added weight plus it may come in handy around the garage door, and other areas I can't get the blower in, if the snow doesn't amount to much I will just unhitch and install the front blade, use a :wh:.
Edited by WVHillbilly520H
  • Excellent 4
elcamino/wheelhorse
You know we will want pictures/video when you blow the mess that we are supposed to get tomorrow. Nice snow eater.
  • Like 4
DennisThornton
On 1/10/2021 at 6:49 PM, WVHillbilly520H said:
@WHX24, @PeacemakerJack, @ebinmaine, @JCM, @shallowwatersailor, @pullstart, @Horse Newbie, @elcamino/wheelhorse, @Ed Kennell, and the rest of RS ....
As I have mentioned before I would be getting snow removal tools for my Mahindra eMax 22, the whole package plow, blower and soft cab, I had purchased a Kubota set-up a couple years back with the intentions of modifying it to fit/work with it but after careful consideration decided just to sell it to help pay for the correct set-up built for Mahindra (by Berco in Canada), I ordered it the end of October and its showed at the dealer in PA right before Christmas and I just picked it up Friday, and today got the sub-frame (which both the plow and blower use so you can switch between with ease) assembled and mounting brackets installed on the tractor frame (the only thing I don't like is you have to switch these brackets back and forth between this and the mower deck mounts "not quite WH easy" but after a few times it may not be so bad :eusa-think:), then installed the sub-frame , snow plow and ran the hydraulic lines and plugged into the loader/sector valve. The cab and blower assembly will follow within the next few days/weeks. Pics and a little video of it in operation.
This is awesome!  Super HD!
  • Excellent 1
  • Thanks 1
WVHillbilly520H
16 minutes ago, DennisThornton said:
Ain't no "farm" tractor or "bull dozer" but been pleasantly surprised by the capabilities of this one and the bit bigger Kioti in WV.
  • Like 4
WVHillbilly520H
Jim, from different forecast models you may get more than me if it stays along I-95 instead of I-81, who knows its may be nothing or it may be a "whopper" of a Nor'Easter. Either way I am well prepared.
  • Like 3
ebinmaine
Excellent set-up there Jeff.
  • Thanks 1
elcamino/wheelhorse
My wife made her usual forecast " anything from nothing to a foot " .
  • Haha 2
Horse Newbie
I would say you are...that plow and that blower is nice !
... the difference between men and boys...
Man you look like you have declared war on the snow !
Edited by Horse Newbie
WVHillbilly520H
... thr difference between men and boys...
Yes I have, and i hate the alternative, a shovel.
  • Haha 1
Tractorhead
Whatever the forecast say‘s i just believe my own eyesight.
They Weatherfrogs here be not a 2Week right this year. Told the whole Winter about „ catastrophic Snowmasses of 3 inch..“ 😂😂😂
Think somebody forgot to tell this clowns - hey, it‘s Winter So snow can happen thats normal in that season.
and 3 inch is not really much. And what you defined as „mass of Snow“ is in the eye of a beholder.
Out of that It‘s allway‘s better to be prepared for the worst.
Also this year only heavy Snow for 3 Weeks but also with good equippment you be prepared to have Fun and be good.
Nothing can shock you, i even thinkering on a Snowblower, because it‘s easier than only the Blade and FEL.
But your Rigs looking pretty Cool @DennisThornton & @WVHillbilly520H.
Not Annoy’s, just a Question just for my understanding  @WVHillbilly520H
In your first Vid. the chimney you steer by hydraulics runs opposite my logical thinking from driverseat,
was that fixed or can this be changed individually?
i think when i put lever left, chimney should be rotated to left and vice versa.
it‘s just my humble opinion and also just a question, if it can be switched.
WVHillbilly520H
@Tractorhead, yes the hose routing connection points can all be changed to different ports, first 2 that I plugged in after removing the blade, after I got them exactly where I want them i will mark the hoses with the corresponding color tape or wire tie, usually red green yellow white.
  • Thanks 1
WVHillbilly520H
Looks like I will be trying out the new toys after all.
  • Like 4
ebinmaine
Yer a day ahead of us bub.
We're forecasted for 12+ starting Monday afternoon through Tuesday evening.
WVHillbilly520H
Original forecast was late Saturday night through early Tuesday morning for us, might still be.
ebinmaine
Wow
WVHillbilly520H
Last time I cared enough to record what they put out...
Tractorhead
For such purposes i like Colored Zipties, simply to mount and if things changin the can also be changed quick.
Pollack Pete
Nice Mahindra.That blower looks HUGE on it.Big storm commin' here tomorrow.Gonna last 2 or 3 days.The weather man first said maybe 4 to 6 in.Now they're up to 12 to 18 in.Hope they're wrong all together.Come on Spring........PS  I like the cab too.
Edited by Pollack Pete
  • Like 3
  • Thanks 1
WVHillbilly520H
Your eMax 25 has the 56" blower correct? It could just be my camera angle.
Horse Newbie
Good googley moogley !... Ya'll got it !
  • Thanks 1
Pollack Pete
Yup,same 56 in blower.I guess I never looked at mine at THAT angle.Mine's gonna get another work out in a day or two.That tractor is one  of the better investments that I've made.
  • Excellent 1
WVHillbilly520H
I might have miscalculated the moisture content of this snow a bit, even though it did good, the slush at the end of the drive from the DOT clogged the chute a couple times, didn't help the ground wasn't frozen and the soft clay soil was getting picked up along with grass either, definitely needed the rear blade for traction and ballast weight. Cab kept me dry and fairly warm has vents at the top of both sides keeps the fumes and fogging to a minimum. Here is the evidence.
  • Excellent 3
WVHillbilly520H
Before I started last measurement was right at 7", by the time I came in it might have been 5.5" from settling as the temperature rose. Started snowing some real fine stuff as the sun was going down, calling for another 1" or so overnight and freezing rain.
  • Similar Content
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
