WVHillbilly520H
My other Red tractor
Horse Newbie
Wish I had some snow to move, but I don't want to move closer to the North Pole !
Let me add " as soon as I get my 520H back in service"
Edited by Horse Newbie
  • Haha 1
Tractorhead
Seem it works pretty fairly well, also on Slushy (Wet) Snow...
Ok about the Cabin i prefer a hard Windscreen but that‘s my personal taste.
Cool Gadgets for the Tracta.
The best is, you have the snow immediately far away instead of Plow...
I have to Thinkering about that.
ebinmaine
That's why we have the walk behind snowblower.
WVHillbilly520H
Hard cab/windscreen for my tractor is a permanent fixture and like $3000+, this was $500 easy on and off now.
Pollack Pete
12 hours ago, WVHillbilly520H said:
I might have miscalculated the moisture content of this snow a bit, even though it did good, the slush at the end of the drive from the DOT clogged the chute a couple times, didn't help the ground wasn't frozen and the soft clay soil was getting picked up along with grass either, definitely needed the rear blade for traction and ballast weight. Cab kept me dry and fairly warm has vents at the top of both sides keeps the fumes and fogging to a minimum. Here is the evidence.
So other than the chute clogging a couple times,it did OK?Mine has only plugged a couple times in the 4 years that I've owned it.I find that when I get into the real slushy stuff,I have to slow down to a crawl.Plus I always keep the engine RPM's up pretty high when using the blower.I think that as you use it and experiment a little,you'll learn the little tricks to tune right in for effecient snow removal.
Pollack Pete
Pollack Pete
WVHillbilly520H
My tractor is gear drive, for most of the time I was in Lo range second @ 3000 rpm, I don't have an overrunning clutch so when I go to stop with the clutch depressed the PTO disengages until I kick it in neutral let clutch back out and let the blower run to empty itself, then on occasion next to the main highway I didn't always get to do that and then it clogged up, and as I use it more I will learn its tricks, also the those "lawyer" fingers (stone deflector wires may be coming off/out as well, thank you for your input greatly appreciated.
Edited by WVHillbilly520H
Pollack Pete
I've thought many times about removing those lawyer fingers too.They DO attract slushy snow.My Emax 25 has hydro drive and an electric clutch for the PTO.You'll have to learn a whole bunch of new tricks with yours.I'm surprised there's so many differences between Mahindra 22 and 25.Learn something new every day.
WVHillbilly520H
@WHX24, @ebinmaine, @Horse Newbie, @953 nut, @Ed Kennell, @JCM, @pullstart, @Pollack Pete
Today I tried out the snow plow as this was a very wet and heavy snow more so than last Sunday, some videos for your entertainment... Wish I would have gotten a couple from inside the cab while "rolling" the snow , it did so fairly well but even with 4wd that big ole blade and wet heavy snow will push the tractor side ways (chains on all 4 may be in the future?)
  • Like 4
  • Excellent 3
ebinmaine
snow plow
Looks fantastic!
Pushes strong.
I'd venture to say that was a winner!
  • Excellent 2
Pollack Pete
That IS a snow plowing machine.Looks like it did a great job.Only about 1 inch here today.Just went out and shoveled a path to the chicken coop.VERY icy underneath from a little melting the last couple days.
WVHillbilly520H
1 hour ago, ebinmaine said:
Looks fantastic!
Pushes strong.
This is why we have both, plow and blower, this machine and the :wh:'s you just never know what Mother Nature will blow your way, and just for the record, the Horses aren't going anywhere, gotta have back ups, right @WHX24?
ebinmaine
And backups for your backups for your backups.
  • Haha 2
WHX??
Got that right ....Murphys law yer gonna have problems when you need it most.
  • Excellent 2
WVHillbilly520H
Woke up to this today already...
  • Similar Content
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
