WHX?? 48,839 #151 Posted February 25, 2021 Awesome sounding Mick good job! Nice to see solid shaker plate mounts. 1 Share this post Link to post Share on other sites
Mickwhitt 4,645 #152 Posted February 25, 2021 Took these just now. The ones from my first strip down are on a computer but I can't be sure the layout was right back then. This all works just fine as it is. Hope this shows the layout clearly. Mick Share this post Link to post Share on other sites
WHX?? 48,839 #153 Posted February 25, 2021 Looks to be as should. Missing a hairpin on the PTO trunion tho and what is that brass lookin dodad on the end of the throttle cable? 1 Share this post Link to post Share on other sites
Gregor 4,846 #154 Posted February 25, 2021 (edited) Thank You. That's not at all like mine. I have a wheel with several holes, and a torsion spring. I never have gotten it to work like I think it should, but then, I'm not sure all the bits and pieces are there either. I was told this motor came from a roto tiller. I don't think it had a throttle cable originally. Maybe I could get the parts and switch it to a system like yours. Edited February 25, 2021 by Gregor Share this post Link to post Share on other sites
squonk 41,169 #155 Posted February 25, 2021 I think you're comparing a small block Kohler linkage to a big block which is a different set up. 2 Share this post Link to post Share on other sites
Mickwhitt 4,645 #156 Posted February 25, 2021 If you look closely its missing the PTO clutch plate too. The brass do dad is an extension piece for the throttle cable. It was too short and so I made a little clamp on brass sleeve with a piece of wire soldered in. Share this post Link to post Share on other sites
Gregor 4,846 #157 Posted February 25, 2021 I don't know. Mine is a K161 also. I really don't know what you mean by small and big block, to tell you the truth. Share this post Link to post Share on other sites
squonk 41,169 #158 Posted February 25, 2021 2 minutes ago, Gregor said: I don't know. Mine is a K161 also. I really don't know what you mean by small and big block, to tell you the truth. Mick's is a K301 12 HP. 10HP and up are big blocks. 4,7 and 8's are small blocks. Share this post Link to post Share on other sites
Gregor 4,846 #159 Posted February 25, 2021 Oh duh. I knew that. I was thinking it was a 7hp. for some reason. Share this post Link to post Share on other sites
