TJ5208
opinions on ags & tri ribs
RandyLittrell
TJ5208
well im glad to know that i wont bend the axle
TJ5208
what kind of bushings
TJ5208
i have a question can you fill tires without a tube
Achto
Yes, if you use RV antifreeze or Rim Saver fluid
TJ5208
Okay do you have one with rv antifreeze
Achto
For the axle spacers some thing on this line would work. Important dimensions will be inside diameter (3/4 inch) and the length that you need.
https://www.lowbrowcustoms.com/products/3-4-inch-id-x-3-4-inch-long-aluminum-motorcycle-wheel-axle-spacers-pair?variant=31149096370223&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=EAIaIQobChMIspW7mpGU7gIVpuHACh1giAeqEAQYCSABEgJG7vD_BwE
TJ5208
Can you find it on amazon because I can't use any other site because of visa cards
TJ5208
But I regularly buy a amazon card at the store
TJ5208
Im at my braces appointment I have internet my phone does not have a SIM in it I have a chromebook but have no internet at home except a little box Verizon box that don't have much WiFi on it hope you guys understand
Achto
I personally do not have any tractors with loaded tires but many people on this forum do run RV antifreeze in their tires.
 If you search (3/4" i.d. axle spacers) on Amazon, I'm sure that you find some thing.
TJ5208
I'll have to measure the gap so I can get the right one
TJ5208
The best thing is the bearings stick out so that will help I might use washers what do you guys think
Achto
 Washers will work with no problem.
Post a picture of your original rims. I'll be able to tell you if the Deestones will fit on to your original rims. Might be able to save the hassle of spacing out the rims that you showed us.
TJ5208
Well thought it would look wierd both to go leaving internet
TJ5208
I liked the thinner rims
Achto
The rims that are on the front of your tractor are the exact same rims that are on my 1076 and Raider 12. The Deestones will fit those with no issues.
TJ5208
Here's a picture
TJ5208
Thanks Dan aleast I know that now
TJ5208
Got to go
TJ5208
the rims on ole red is 16 6 50 8
Achto
That is the tire size. The rim will only be 4.5 to 5 inches wide. If you look at the picture of my C-141 that I sent you. You can see that those rims have a deep dish & are a lot wider. The C-141 rims would not work with the Deestones.
TJ5208
so are you saying dan they wont work. do you guys think they would look wierd on 16 6 50 8 rims or should i stick with the thin rims. i get my braces off next time i always picked grey i choise red this time for wheel horse i thought since this is my last time id do it  thanks for all the help everyone
Achto
The Deestones should work and look fine on the original :wh: rims that were on the tractor. If you are still uncertain, mount one new tire on to the original rims and see how it looks. If you don't like the look then remove the tire & mount them both on the other rims.
I like the :wh: red braces idea!!
Edited by Achto
TJ5208
thanks it is my last time ill get my braces off next time 6 weeks what happens if the tire streches will it still fit
