kirbet.gensel@yahoo.com 3 #1 Posted January 6, 2021 i broke y drive belt got a new one now when i push clutch pedel idler arm seems to go backward and tightens the belt eve more can anyone help 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #2 Posted January 6, 2021 (edited) @kirbet.gensel@yahoo.com You posted it on the wrong place First off . Edited January 6, 2021 by Maxwell-8 1 1 Share this post Link to post Share on other sites
Achto 28,249 #3 Posted January 6, 2021 @kirbet.gensel@yahoo.com If you could post a picture of you belt routing it would be easier for us to determine the issue. 3 Share this post Link to post Share on other sites
SylvanLakeWH 26,660 #4 Posted January 6, 2021 Can you post a picture of how its threaded through the pulleys? Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #5 Posted January 6, 2021 32 minutes ago, Achto said: @kirbet.gensel@yahoo.com If you could post a picture of you belt routing it would be easier for us to determine the issue. 1 Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #6 Posted January 6, 2021 Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #7 Posted January 6, 2021 my t1057 Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #8 Posted January 6, 2021 20 minutes ago, SylvanLakeWH said: Can you post a picture of how its threaded through the pulleys? i just did 1 Share this post Link to post Share on other sites
Ed Kennell 39,855 #9 Posted January 6, 2021 If the pulley is not moving forward when you push the pedal, you may have sheared the pin that fastens the clutch lever to the cross shaft on the left side. 2 1 Share this post Link to post Share on other sites
pfrederi 18,206 #10 Posted January 6, 2021 When you step on the clutch pedal the idler pulley should rotate towards the front and down loosening the belt 1 Share this post Link to post Share on other sites
Achto 28,249 #11 Posted January 6, 2021 18 minutes ago, kirbet.gensel@yahoo.com said: Everything looks correct. When you step on the brake/clutch pedal the idle pulley should move forward to release the belt. The belt guard also works as a belt brake. The belt will drag and it will be hard to shift without the belt guard installed. 1 Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #12 Posted January 6, 2021 i will have to check the pin Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #13 Posted January 6, 2021 the pin is fine Share this post Link to post Share on other sites
roadapples 6,983 #14 Posted January 6, 2021 Need the belt guard on to work properly... 2 Share this post Link to post Share on other sites
Achto 28,249 #15 Posted January 6, 2021 Does the idle pulley move towards the front of the tractor when you step on the clutch pedal? Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #16 Posted January 6, 2021 Can you show a of what I'm looking for 3 hours ago, Achto said: @kirbet.gensel@yahoo.com If you could post a picture of you belt routing it would be easier for us to determine the issue. Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #17 Posted January 6, 2021 No it goes towards the back tire Share this post Link to post Share on other sites
Maxwell-8 4,366 #18 Posted January 6, 2021 13 minutes ago, kirbet.gensel@yahoo.com said: No it goes towards the back tire You have a problem with your linkage, check if nothing is bent. 1 Share this post Link to post Share on other sites
Pullstart 63,635 #19 Posted January 6, 2021 It all looks right to me too. Like Mr. Jay said, a belt guard is mandatory for proper operation. 1 Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #20 Posted January 6, 2021 On the left side where the linkage hooks together is it to be pointing up or down Share this post Link to post Share on other sites
Achto 28,249 #21 Posted January 6, 2021 7 minutes ago, kirbet.gensel@yahoo.com said: On the left side where the linkage hooks together is it to be pointing up or down The arm on the left side should point up. Some thing similar to the pic below. 1 Share this post Link to post Share on other sites
kirbet.gensel@yahoo.com 3 #22 Posted January 6, 2021 Ok that helps thank you, that brake lever you have on there looks great 1 Share this post Link to post Share on other sites
Achto 28,249 #23 Posted January 6, 2021 16 minutes ago, kirbet.gensel@yahoo.com said: that brake lever you have on there looks great That parking brake lever is one that I made. 3 Share this post Link to post Share on other sites
WHX?? 49,969 #24 Posted January 6, 2021 (edited) Front should look like this Rear should look like this. This is on a 1067 Or this Edited January 6, 2021 by WHX24 4 Share this post Link to post Share on other sites
Ed Kennell 39,855 #25 Posted January 7, 2021 9 hours ago, Achto said: The arm on the left side should point up. Some thing similar to the pic below. Kirbet, does your linkage look like Dans picture or did you take the lever off and assemble it incorrectly on the bottom. Please show us a picture of your assembly on this side. I still have to believe the pin must be sheared off. Look at the two reference punch marks on Dans picture. Mark your lever and shaft, then depress the clutch pedal and see if the lever changes position on the shaft. If it does, the pin is sheared off. 4 1 Share this post Link to post Share on other sites
