DennisThornton 4,771 #1 Posted January 5, 2021 This idea keeps catching my eye. Not sure I'm up to it but I sure like thinking I might! I'd think this would be the easiest way to have a mini dozer after adding independent braking somehow. My 147 Cub has disc brakes that I guess could become independent but I'm not sure what other tractors might work somehow. 4 1 Share this post Link to post Share on other sites
JAinVA 4,629 #2 Posted January 5, 2021 (edited) Cute, but I see nothing to keep the rubber bands on those tires. I deal with crawlers all the time. The tracks have flanged rollers and toothed sprockets to locate them Water or a little mud, tight turn and you get to put the bands back on. Take a look at any large rubber tracked ag tractor There is a row of locating lugs on the inside portion of the bands. Edited January 5, 2021 by JAinVA 2 Share this post Link to post Share on other sites
Maxwell-8 4,366 #3 Posted January 5, 2021 4 hours ago, DennisThornton said: after adding independent braking Ain't that hard, 1inch axle 8speeds, and mount on the axles a 1"disc brake kit https://www.gopowersports.com/go-kart-mechanical-brake-disc-kit-9511-9598-th1000/ 2 Share this post Link to post Share on other sites
ebinmaine 70,789 #4 Posted January 5, 2021 1 hour ago, Maxwell-8 said: Ain't that hard, 1inch axle 8speeds, and mount on the axles a 1"disc brake kit https://www.gopowersports.com/go-kart-mechanical-brake-disc-kit-9511-9598-th1000/ I've been thinking about making a bigger set of brakes for Colossus. Good link. 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #5 Posted January 5, 2021 (edited) 2 minutes ago, ebinmaine said: I've been thinking about making a bigger set of brakes for Colossus. Good link. I think i now a coupon. USE CODE "CC10" FOR 10% OFF Don't now if it still works Edited January 5, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
ebinmaine 70,789 #6 Posted January 5, 2021 2 hours ago, Maxwell-8 said: Ain't that hard, 1inch axle 8speeds, and mount on the axles a 1"disc brake kit https://www.gopowersports.com/go-kart-mechanical-brake-disc-kit-9511-9598-th1000/ I won't be disassembling the transmission at this point to have keyways put into the axles but if I could figure out how to do it by bolting them onto the back of the hubs that would be every kind of neat. 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #8 Posted January 5, 2021 (edited) 8 hours ago, JAinVA said: Cute, but I see nothing to keep the rubber bands on those tires. I deal with crawlers all the time. The tracks have flanged rollers and toothed sprockets to locate them Water or a little mud, tight turn and you get to put the bands back on. Take a look at any large rubber tracked ag tractor There is a row of locating lugs on the inside portion of the bands. I've always thought this method was for dry conditions only. That would sort of defeat the purpose... However, I'd think that ribs or even screws or studs from the inside of the track. Something could be done. Edited January 5, 2021 by DennisThornton Share this post Link to post Share on other sites
Pullstart 64,587 #9 Posted January 5, 2021 (edited) 8 hours ago, JAinVA said: Cute, but I see nothing to keep the rubber bands on those tires. I deal with crawlers all the time. The tracks have flanged rollers and toothed sprockets to locate them Water or a little mud, tight turn and you get to put the bands back on. Take a look at any large rubber tracked ag tractor There is a row of locating lugs on the inside portion of the bands. Jim, I wonder how much of a sidewall could be retained yet still become playable to an oval? I imagine more sidewall = less chance of PING! I realize it’d probably not sound like ping or twang, more like thmbld Edited January 5, 2021 by pullstart 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #10 Posted January 5, 2021 5 hours ago, Maxwell-8 said: Ain't that hard, 1inch axle 8speeds, and mount on the axles a 1"disc brake kit https://www.gopowersports.com/go-kart-mechanical-brake-disc-kit-9511-9598-th1000/ Could see those bored for 1 1/8" to. Nice! 2 Share this post Link to post Share on other sites
DennisThornton 4,771 #11 Posted January 5, 2021 2 hours ago, Maxwell-8 said: I've seen this and others. Another easy way to add tracks. Share this post Link to post Share on other sites
