squonk 41,171 #51 Posted April 3, 2021 1 hour ago, ebinmaine said: I normally use a set of 3/8" bolts going through the hub. I've been afraid I'd pull the threads through. Do you ALWAYS use the threads? The fine thread I'm referring to is on the center bolt. Mine is 7/8" fine thread. A full revolution of the bolt won't move much distance but it will supply more power. I do use 7/16' Fine bolts in the hub. But I also back up the bolts on the inside of the hub with washers and fine 7/16' nuts. 1 Share this post Link to post Share on other sites
Ed Kennell 38,319 #52 Posted April 3, 2021 1 hour ago, ebinmaine said: I normally use a set of 3/8" bolts going through the hub. Same here. and I always use all five bolts and back up the hub side with big washers to spread the load on the hub flange. 1 Share this post Link to post Share on other sites
