haydendavid380
Bought a mystery deck at auction
haydendavid380
I just bought a deck from an online auction. Was listed as a 48"
Is this a D series deck? If so (assuming everything is solid) what would ballpark value be on it? Are they harder to come by than the B/C decks?
roadapples
48 But I don't think D series...
Ed Kennell
The deck looks like a standard 48" shell that would fit a C, 3,4, 0r 500 series,   but I have never seen that type of carriage mount.
Can  you ID Garry @gwest_ca  ?
gwest_ca
I don't know the decks well but the handle on the hitch bar caught my eye. You can see it here - item #43
https://www.partstree.com/models/5-1220-toro-48-side-discharge-mower-deck-1973/parts-list-for-48-18-hp-automatic-0/
Here is a list of all the D-Series decks. I do not know if they all have the handle.
DNA of 48in side discharge decks for the 18hp Auto, D-160 Auto, D-180 Auto and D-200 Auto
1973-1974 model 5-1220
1975 model 5-1221
1976 model 65-48XS01
1977 model 75-48XS01 - Blades up to here have a 5/8" x 3/4" double-D center hole - 3 blade set #100202 no longer available
The following decks use blades with 3/4" round center hole - 3-blade set #106637
1977 model 75-48XS02
1978 model 85-48XS01
1979 model 95-48XS00
1979 model 95-48XS01
1980 model 05-48XS01
1981-1982 model 05-48XS02
Garry
haydendavid380
I hadn't seen that handle before either
pacer
Havent had my D200 deck off in a while but ..... IIRC that is the same deck - and yes it does have that handle.
daveoman1966
That is  'D' series deck...48" for sure.  Just swap out the lift brackets and it will fit almost any B or C series tractors.
haydendavid380
I bought it on the off chance that the belt covers might fit my 42" on my 312 that's missing them. The only tractor I have that's missing a deck is my B-80, and there's no way it's going to run that thing if I swap the brackets.
I would think someone would trade a 36" for it.
