"Manic-Mechanic" 1,228 #1 Posted December 29, 2020 Hello, I have a decal that I applied and removed too many times, is there an adhesive I can use? Tried Loctite spray adhesive but it didn't flatten out enough. 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #2 Posted December 29, 2020 (edited) 12 minutes ago, oldman said: Hello, I have a decal that I applied and removed too many times, is there an adhesive I can use? Tried Loctite spray adhesive but it didn't flatten out enough. Contact glue, maybe Edited December 29, 2020 by Maxwell-8 2 Share this post Link to post Share on other sites
ebinmaine 70,792 #3 Posted December 29, 2020 We have a 3M spray adhesive at home of some sort. I can get you the number in a bit. What is the decal made of and what are you trying to stick it to? Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #5 Posted December 29, 2020 It's a vinyl Toro 111312 danger decal from Terry. Enamel Painted Metal on my 312-8. I "think" I may have some of that 3M, maybe spray it and burb it, then apply? I thought someone had used similar, but want to do this once, "hopefully", lol! Been wicked of late as my enthusiasm has decreased a bit, albeit It's moving along....... 1 Share this post Link to post Share on other sites
ebinmaine 70,792 #6 Posted December 29, 2020 You may want to give Terry a ring just to make sure that's going to be compatible. Was it me I would put a pretty light coat on a sticker like that and then maybe try to apply it right down the center and spread to the sides... 1 Share this post Link to post Share on other sites
RandyLittrell 3,894 #7 Posted December 29, 2020 If your decal still has adhesive on it, but just not sticky anymore, we used this in the bodyshop. 3M also makes a single use version, but this is much cheaper. It will also work to help make any plastic products sticky to help you adhere double sided tape. Share this post Link to post Share on other sites
WHNJ701 4,165 #8 Posted December 29, 2020 Wouldn't it be easier just to order a new decal? 4 Share this post Link to post Share on other sites
Racinbob 11,727 #9 Posted December 29, 2020 44 minutes ago, ebinmaine said: You may want to give Terry a ring just to make sure that's going to be compatible. Was it me I would put a pretty light coat on a sticker like that and then maybe try to apply it right down the center and spread to the sides... Asking @Vinylguy is the best idea. 31 minutes ago, jabelman said: Wouldn't it be easier just to order a new decal? Except for this even better idea. Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #10 Posted December 29, 2020 Has anyone called Terry of late? That's the best answer I can give with respect to that suggestion, he may need a break for a short spell. Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #11 Posted December 29, 2020 45 minutes ago, Racinbob said: Asking @Vinylguy is the best idea. Except for this even better idea. I did reach Terry before the holidays and asked that same question, he had no suggestions. Usually a replacement is easier and one was sent, but it was the wrong one. I believe commercial work is priority for a bit right now. Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #12 Posted December 29, 2020 1 hour ago, ebinmaine said: You may want to give Terry a ring just to make sure that's going to be compatible. Was it me I would put a pretty light coat on a sticker like that and then maybe try to apply it right down the center and spread to the sides... He had no suggestion aside from a new one. 1 Share this post Link to post Share on other sites
AMC RULES 37,147 #13 Posted December 29, 2020 LOL! 1 1 Share this post Link to post Share on other sites
76c12091520h 3,788 #14 Posted December 29, 2020 None of the spray products will lay down flat on a decal. Take your old decal, lay it face down and clean off all the old adhesive using some type of wax and grease remover, rubbing alcohol, etc. Once it's clean and dry press it onto this transfer adhesive. When you remove it from the adhesive strip, the adhesive will stick to your decal and you're back in business. 3 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #15 Posted December 29, 2020 I really like this product, going to look into that. However, Terry did call back! He is still swamped but doing well again, Thank God! 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #16 Posted December 29, 2020 (edited) 2 hours ago, AMC RULES said: LOL! Yes, it was puzzling? Edited December 29, 2020 by oldman Share this post Link to post Share on other sites
