Tony in Australia 2
Kohler Maginum 12hp Air cleaner element replacement
Tony in Australia 2
Marry Xmas Red Square members from Tony down under Australia.
As with all things if need to know ask the experts.
Once again I am in need of you expertise.
I am unable to find an Air Cleaner element for my Kohler Maginum 12hp down here, is there an alternative make that uses the same filter or an alternative part number then KH10236?
The part shops down here are not that helpful with something outside of their box, if you know what I mean.
Thanks for you time gentlemen. Cheers Tony
gwest_ca
6" OD x 4-5/8" ID x 3" HT
Kohler 4508302, 4508302-S, 4508302-S1 with pre-filter replaced by 4588302-S1
Onan 1401216
Toro/Wheel Horse KH10236
Toro/Wheel Horse pre-filter KH10235
Napa 7-02226
Stens 100-065, 055-017
Stens with pre-filter 055-421
Stens pre-filter 100-768
Wix 42299
  • Excellent 1
Tony in Australia 2
Thanks alot,  that  should do the trick. Cheers
