DennisThornton 4,769 #1 Posted December 26, 2020 Tiny URL https://tinyurl.com/ybtfmevu Plating at home is somewhat complicated and chroming at home is REALLY not a good idea or very practical either. Dangerous chemicals and some pretty expensive DC power supplies to be able to plate anything of size. I have a hobby shop plating system that will sudo chrome small pieces such as hand tools but I couldn't begin to plate a hubcap or valve cover! (Yet...) Even if I up the power supply real chrome still won't be my goal. HOWEVER! Look at that valve cover shine! I'm guessing that up close it still won't look like real chrome but it sure beats anything I've seen come out of a spray can! I've yet to powder coat anything but I've done a ton of research and it wouldn't take much to get into it. So I ask for any opinions? Best spray can chrome? Any first hand experience seeing or actually powder coating "Chrome"? Any at home DIY powder coating? 2 Share this post Link to post Share on other sites
Sarthurs01 825 #2 Posted December 26, 2020 I may not have done it at home, but we have all the powder coat needs at work.. I tried out the powder coat chrome on the steering shaft in the battery tie down in the brake and clutch rod too. 7 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #3 Posted December 26, 2020 Spray can chrome always seems to look like you used spray can chrome...... I have a can of old dupli color chrome high heat engine that I picked up somewhere. I used it on some small parts didn't look to bad. 1 2 Share this post Link to post Share on other sites
ebinmaine 67,717 #4 Posted December 26, 2020 45 minutes ago, jabelman said: Spray can chrome always seems to look like you used spray can chrome Agreed. To me it looks like super super fine metallic silver paint. There are much newer paints on the market than I've tried. No need to chrome anything yet but I'm curious to have a first hand physical look at the "modern" sprays. Seems I've seen a 2 or 3 stage setup that supposedly gets good results. 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #5 Posted December 26, 2020 1 hour ago, Sarthurs01 said: I may not have done it at home, but we have all the powder coat needs at work.. I tried out the powder coat chrome on the steering shaft in the battery tie down in the brake and clutch rod too. What do you think of the "Chrome"? Share this post Link to post Share on other sites
Sarthurs01 825 #6 Posted December 27, 2020 23 hours ago, DennisThornton said: What do you think of the "Chrome"? It’s not to bad. Looks better the out of a spray can but just isn’t the real thing. From 10 feet back you would say it’s real but up close it’s little hazy looking. 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #7 Posted December 27, 2020 1 hour ago, Sarthurs01 said: It’s not to bad. Looks better the out of a spray can but just isn’t the real thing. From 10 feet back you would say it’s real but up close it’s little hazy looking. That's about what I expected. So better than any other choice except plating? Share this post Link to post Share on other sites
Sarthurs01 825 #8 Posted December 27, 2020 1 minute ago, DennisThornton said: That's about what I expected. So better than any other choice except plating? I’ve seen on YouTube there is a 3 step sealer base coat clear for doing it but never seen it in person. 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #9 Posted December 27, 2020 Personally I don't like chrome, alot of times I think it's way over used, gets scratched, and looks gaudy. To each there own. Exhaust, small details, lug nuts it looks ok. I like the looks of some of the other shades of metallic paints. I repainted the heat registers in my house a cast iron color which looks neat. Some of the shades of the hammered paint are cool looking. 2 Share this post Link to post Share on other sites
DennisThornton 4,769 #10 Posted December 27, 2020 42 minutes ago, jabelman said: Personally I don't like chrome, alot of times I think it's way over used, gets scratched, and looks gaudy. To each there own. Exhaust, small details, lug nuts it looks ok. I like the looks of some of the other shades of metallic paints. I repainted the heat registers in my house a cast iron color which looks neat. Some of the shades of the hammered paint are cool looking. Everything can be overdone. Good plating is also a great rust preventative and protector but for sure it's not for everything and not every project deserves the costs of platting and not everyone can afford it but perhaps some could settle for spray can or powder coat. Share this post Link to post Share on other sites
pfrederi 17,741 #11 Posted December 27, 2020 I am sort of with jabelman some how to me the words tractor and chrome do not go together... 2 Share this post Link to post Share on other sites
Skipper 1,788 #12 Posted December 28, 2020 An alternative could be water based crome/silvering solution. Easy to do, not that expensive, and I like the more silvery tone compared to chrome. I'm sort of also with jabelman, but some projects just beg for a lot of brightwork 1 Share this post Link to post Share on other sites
Oldskool 6,644 #13 Posted December 28, 2020 (edited) I've tried the spray can chrome. Not a fan. Better off using silver/metallic base/clear coat paint. Thought about the spray chrome from Eastwood but haven't made it that far yet. Although I have a can from Sherwin William's I acquired. Havent tried it yet either lol. Here is the number if anybody wants to try Edited December 28, 2020 by Oldskool 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #14 Posted December 28, 2020 2 hours ago, Skipper said: An alternative could be water based crome/silvering solution. Easy to do, not that expensive, and I like the more silvery tone compared to chrome. I'm sort of also with jabelman, but some projects just beg for a lot of brightwork I've seen some incredible YouTubes silvering whole cars! But I just assumed it was outside my budget. I'll have to check that out! Thanks! 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #15 Posted December 28, 2020 27 minutes ago, Oldskool said: I've tried the spray can chrome. Not a fan. Better off using silver/metallic base/clear coat paint. Thought about the spray chrome from Eastwood but haven't made it that far yet. Although I have a can from Sherwin William's I acquired. Havent tried it yet either lol. Here is the number if anybody wants to try I'm not finding much with Google other than a 1972 Imported Car Colors index Share this post Link to post Share on other sites
Oldskool 6,644 #16 Posted December 28, 2020 4 minutes ago, DennisThornton said: I'm not finding much with Google other than a 1972 Imported Car Colors index I think this can may be as old as I am Share this post Link to post Share on other sites
DennisThornton 4,769 #17 Posted December 28, 2020 4 minutes ago, Oldskool said: I think this can may be as old as I am It's old. Possibly NLA... Share this post Link to post Share on other sites
Oldskool 6,644 #18 Posted December 28, 2020 1 hour ago, DennisThornton said: It's old. Possibly NLA... Probably not. Wasnt sure if any could be mixed from the number Share this post Link to post Share on other sites
Skipper 1,788 #19 Posted December 28, 2020 3 hours ago, DennisThornton said: I've seen some incredible YouTubes silvering whole cars! But I just assumed it was outside my budget. I'll have to check that out! Thanks! https://angelgilding.com/spray-chrome.html I source the items for it here. Very nice people, and they can help put a cheap beginners kit together. 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #20 Posted December 28, 2020 14 minutes ago, Skipper said: https://angelgilding.com/spray-chrome.html I source the items for it here. Very nice people, and they can help put a cheap beginners kit together. More expensive than powder coat but from what I've seen more like a mirror too! Thanks for the link! 1 Share this post Link to post Share on other sites
Skipper 1,788 #21 Posted December 28, 2020 They put a silvering set together for me that will cover 260 sq. ft. it was like 230$. You can "chrome" a lot of parts with that, but it does take some careful preparation of the items, and does not include the preparation costs, or clear coat to seal it inn. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #22 Posted December 29, 2020 @Horse Newbie, Tim show Dennis the "chrome" powder coat on your wheel covers. Share this post Link to post Share on other sites
DennisThornton 4,769 #23 Posted December 29, 2020 2 hours ago, Skipper said: They put a silvering set together for me that will cover 260 sq. ft. it was like 230$. You can "chrome" a lot of parts with that, but it does take some careful preparation of the items, and does not include the preparation costs, or clear coat to seal it inn. Even better. I think some folks believe that plating covers scratches and flaws, if anything it makes them more noticeable. I have little knowledge of this product. So you have used this product? Please share more info and pics if you have them. 1 Share this post Link to post Share on other sites
Horse Newbie 7,077 #24 Posted December 29, 2020 (edited) 1 hour ago, WVHillbilly520H said: @Horse Newbie, Tim show Dennis the "chrome" powder coat on your wheel covers. @WVHillbilly520H @DennisThornton Here ya go... Color: Super Chrome Manufacturer: Tiger Drylac I don't think they covered it with clear coat, at least I didn't think to mention clear coat the the guys that did it. Tim (Horse Newbie) Edited December 29, 2020 by Horse Newbie 1 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #25 Posted December 29, 2020 2 minutes ago, Horse Newbie said: @WVHillbilly520H @DennisThornton Here ya go... Color: Super Chrome Manufacturer: Tiger Drylac I don't think they covered it woth clear coat, at least I didn't think to mention clear coat the the guys that did it. Tim (Horse Newbie) This is what prompted me to start this topic. Got me thinking! 1 Share this post Link to post Share on other sites
