Crmaverick 91 #1 Posted December 19, 2020 Does any know what this is called and used for? The one I have is without the side wing attachment bolted on. Also what are those side wing attachments used for? 3 Share this post Link to post Share on other sites
pfrederi 17,540 #2 Posted December 19, 2020 (edited) Hilling things like potatoes or spargel (white asparagus) Edited December 19, 2020 by pfrederi 4 Share this post Link to post Share on other sites
Crmaverick 91 #3 Posted December 19, 2020 19 minutes ago, pfrederi said: Hilling things like potatoes or spargel (white asparagus) Cool what’s the purpose of those side wing pieces that bolt on, do you need them? Share this post Link to post Share on other sites
DennisThornton 4,769 #4 Posted December 19, 2020 Furrower blade, with FURROWER sidewings. For bigger furrow. 2 1 Share this post Link to post Share on other sites
Chaz54 57 #5 Posted December 19, 2020 Typically the were mounted on a Troy-Bilt tiller. - it is a Hiller/Furrower attachment. 1977GardenWayHiller-FurrowerForPonyTillerWM.pdf 2 1 Share this post Link to post Share on other sites
Darb1964 1,039 #6 Posted December 19, 2020 That looks a lot like the kind that go on a troy built tiller. With the wings off you can control the depth for how deep you want to plant a certain crop. Put the wings on when the plant gets to a desired height to furrow up. I usually put fertilizer in the center of the row and then use the furrow to move the fertilizer on the side of your crop. Good for corn, potatoes,bush beans and many others. You could use it to plow but a little light for hard ground 6 Share this post Link to post Share on other sites
slim67 2,735 #7 Posted December 19, 2020 I have the same set up for my troybilt aka the wheelhorse of tillers 4 Share this post Link to post Share on other sites
953 nut 54,647 #8 Posted December 19, 2020 With or without the wings this can also be used to turn potatoes up out of the ground. They are also known as middle busters. 3 Share this post Link to post Share on other sites
