bc.gold 3,403 #1 Posted December 16, 2020 Turned the shank down to fit .500" drill, bench test engines ie: mag and compression some first starts for barn finds. 1 Share this post Link to post Share on other sites
Pullstart 63,219 #2 Posted December 16, 2020 15 minutes ago, bcgold said: Turned the shank down to fit .500" drill, bench test engines ie: mag and compression some first starts for barn finds. what do you stick the square in... just a socket? 1 1 Share this post Link to post Share on other sites
8ntruck 7,194 #3 Posted December 16, 2020 11 minutes ago, pullstart said: what do you stick the square in... just a socket? Probably a socket to fit the flywheel nut. 1 Share this post Link to post Share on other sites
Ed Kennell 39,289 #4 Posted December 16, 2020 Had some experience with these hand held drill starters. Things get pretty knarly when the engine fires and you can't get the starter disengaged. 4 3 Share this post Link to post Share on other sites
Tractorhead 9,065 #5 Posted December 16, 2020 2 hours ago, Ed Kennell said: Had some experience with these hand held drill starters. Things get pretty knarly when the engine fires and you can't get the starter disengaged. You have to be quick, or fast - jump out of the Way and enjoy the result... 😎 Share this post Link to post Share on other sites
JoeM 7,874 #6 Posted December 16, 2020 10 hours ago, Ed Kennell said: hand held drill starters put one on the nut of a small Tecumseh because I was tired to pulling. Bucked when fired splitting the flywheel cone at the taper. I suppose it tightened the nut too tight rather then my wrist. That there job went to replacement. Share this post Link to post Share on other sites
