DennisThornton
Rust removal. Chemicals and electrolysis
DennisThornton
One of the best vids I've seen comparing and explaining rust removal.  Nothing new or earth shaking but a good summary of most of the methods I'm familiar with.  Absolutely Great for a beginner!
  • Like 4
  • Excellent 4
ebinmaine
Nicely done comparison
tom2p
recently learned something about EvapoRust :   it does not work well in low / cold temperatures
had some rusted fasteners in a small container of EvapoRust in the cold garage - barely any rust was removed after 3 days
moved the container to the basement - 2 days later the rust was removed
tom2p
many that use the vinegar method use distilled vinegar with a couple of tablespoons of table salt
the addition of salt might increase the effectiveness of the vinegar
DennisThornton
Never tried salt with the vinegar.
tom2p
I believe the combo yields a mild form of hydrochloric acid  ?
DennisThornton
Google results are mixed but it would certainly be easy enough to try.
A warning to all, check often.  I ruined an antique "slick" (huge push chisel!).  The vinegar was more active on the high carbon cutting edge and dissolved most of it.  Overall it's a safe and slow process but watch precision and high carbon steels more often.
WHNJ701
Should also note, it's not good to soak cast iron parts
rmaynard
I use that combination to remove rust from cast iron frying pans.
Charbs152
I use an etank to restore vintage cast iron pans.  works awesome
Maxwell-8
Vinegar, isn't the best for me, i painted it on some wheels and the deep rust got less, but there was more surface rust. Couldn't was it of, so sanding was the only option. I am  gone drop off the rims to get sandblasted.
Would it be worth getting a sandblast set-up?
Edited by Maxwell-8
ebinmaine
Sandblasting cabinet is one of those tools that is a larger investment and very much worth it to you if you're going to be planning on doing multiple restorations and repairs over the next few years..
Maxwell-8
Do you have one?
The thing is you have to remove ALL the rust, or you did all that effort for nothing. I feel you can only accomplish it with a sandblaster.
Edited by Maxwell-8
ebinmaine
4 minutes ago, Maxwell-8 said:
Do you have one?
No sir I do not but I have a very unique home situation.
My other half, life partner, BBT, Trina is an extremely ambitious little woman who needs to be moving all the time and she has been doing much of the cleaning and rust removal for us.
  • Heart 1
Maxwell-8
You are a lucky men. She doing it with just sandpaper?
ebinmaine
Most of what she does is wire brush on an auto body grinder.
Sometimes a chemical spray, sometimes sandpaper...
Wheel Horse 3D
Some small black pipe fittings plumbed to your air nozzle, some hose, a cabinet, and some sand!
