formariz
Gear reduction K91
formariz
Trying to sort out inventory here for some new projects. Does any one know offhand at what speed the shaft on a K91 with gear reduction turns?
pfrederi
Most gear reduction are 6 to 1  so 3600 rpm would be 600
WHNJ701
I can look tonight in my kohler books, but as said it's 6 to 1
formariz
That would be great for me. So using the throttle it will be adjustable down to about 33 rpms at 2000. I may give it a try for my large grindstone. Just need to get it started.
Edited by formariz
WHNJ701
71_Bronco
What if you were to put a gear-reduction K91 into a Wheel Horse? With a 6:1 gear reduction, your ground speed would obviously suffer, almost like driving in low-range on an 8-speed I would imagine.
Would this in theory increase your "pulling power"? I know that is more dependent on traction as well. Or would this just be a way to make a ridiculously slow tractor? :eusa-think:
formariz
@jabelman.  What kind of oil does manual specify for gear box? Same as engine?
I had this engine for at least 16 years. Never started it. Came with other things. Cleaned it up put in a carburetor and recoil which didn’t have, fired up on first two pulls. Got to love Kohlers.
formariz
Probably will prove to be unusable on a tractor. I am not sure what they usually were used on and I thought I would never use it, but now I find it perfect for this application since it will not only turn it real slow but makes the RPMs adjustable by using throttle.
Glad I kept it.
DennisThornton
Overkill for a grindstone!:text-lol:
  • Haha 1
formariz
For sure but why not? Got to use some of the stock here. It’s also going to have an electric option for indoor use.:)
DennisThornton
Not sure what I'd use it for...
WHNJ701
I used to sell alot gear reduction parts that I came across,  mostly briggs stuff to people that restored old walk behinds
WHNJ701
R Scheer
Wouldn't that be 333 rpm?  2000/6
formariz
Oops yes. It gets reduced further by large pulley on wheel. Trying for a maximum of about 60RPMs . I have two  one at 10” and one at 17”.
Should be able to achieve that with the 10” pulley and a 3” pulley on engine with it just idling at 1200 therefore turning engine pulley at 200.
Edited by formariz
oliver2-44
Since the K91 is a splash lube system would it be better to have the engine running at higher than idle. Some on here have recommended Kohler be fun at 3/4 rpm or higher for extended runs
What say you RedSquare Kohler Guru’s
formariz
I can switch to he 17” pulley on stone to have engine rev a little higher and also go to a smaller one on engine. However this set up will only run once in a blue moon probably not long enough to do damage. I understand and agree the dangers to the engine from running at low RPM for extended periods but in reality here there are so many other engines that I may never have the opportunity to use in my lifetime that the demise of one would be inconsequential.
953 nut
We had a Diaphragm Trash Pump to move water from the pond on the farm that had a gear reduction engine.
Vurge
I've got an old Briggs gear reduction off a chemical sprayer pump. I've always suspected that the 6:1 reduction is to match a standard tractor PTO that runs at about 540 rpm.
Handy Don
Sounds plausible to me. These useful ratios are rarely coincidental--engine company engineers were always thinking about how to get companies to use their products. My brother-in-law has an orchard sprayer on a hand cart with a gear-reduced 1.5hp Briggs. Gotta say it is a very cute little motor and it sure does the job for his dozen or so trees.
