DennisThornton 4,769 #26 Posted December 10, 2020 2 hours ago, Stormin said: I could be wrong, but I don't think a chuck will fit on those treads. I wondering if it's a kind of bench grinder. If there is no wick under those cups, then for grease not oil. Pack the cup with grease, refit then screw down now and then. Then good for any position! 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #27 Posted December 10, 2020 (edited) 3 hours ago, Stormin said: I could be wrong, but I don't think a chuck will fit on those treads. I wondering if it's a kind of bench grinder. If there is no wick under those cups, then for grease not oil. Pack the cup with grease, refit then screw down now and then. Good catch! Edited December 10, 2020 by DennisThornton Share this post Link to post Share on other sites
DennisThornton 4,769 #28 Posted December 10, 2020 Could the screw inside the handle be used to adjust the clutch pressure and the "washers" with lobes allow for different pressure settings? Seems there's more than just an engage/disengage mechanism. Share this post Link to post Share on other sites
