Rusty Tinsnips
Do I need special transmission oil?
Rusty Tinsnips
Should I be putting in oil that is specifically made for limited slip rear ends?
This is for a 1972 Raider 14
ebinmaine
No worries. Not needed.
The limited slip axle that Wheelhorse uses is done with metal to metal contact with a special tension spring and not with clutches that need any kind of friction modifier.
If you have a hydro you can use old school type a/dexron. NAPA part number 75 - 200.
if you have a gear drive eight speed or six speed you can use whatever your least expensive 80w 90 is available.
Rusty Tinsnips
Thank you sir.
squonk
All modern gear oils are limited slip capable right out of the bottle. Back in the 80's we used GM limited slip additive to quiet rocker arm squawk in the Iron Duke 4 banger motors. :banana-wrench:
clueless
The old Iron Duke was and still is a noisy, not to powerful and a gas hog but was a work horse.
ebinmaine
Those things were about as unkillable as an engine could get at that time
That was back when newspapers were made out of paper and they were distributed to people with paper boxes and they read the paper.
Remember paper newspapers?
Our carriers had Celebrities and Citations for that reason.
squonk
When I was at Napa I worked with a guy who had a Citation to deliver papers. I rigged a back-up alarm to his left turn signal whilst he was out delivering parts. Everytime he turned left, BEEP BEEP BEEP! :ROTF:
  • Haha 1
tom2p
the Citation ... almost forgot about that one
back in the Roger Smith days ... (former head of GM) ... somehow GM survived those days
(although the decline was well in progress before Smith took over)
tom2p
was the Iron Duke the 4 cyl in the Fiero ?
I recall Fiero fires were often the result of hot oil from a broken engine block (when a rod broke through the block)
( yep - 2.5L Iron Duke a just googled it )
Edited by tom2p
