Man In Black 3 #1 Posted December 4, 2020 Hi, I recently asked the question about using an electric fuel pump on my 8hp Wheel Horse tractor and was told that a 2.5-4 psi would work and I have been looking at some videos on U-tube showing also including a pressure regulator to not over pressure the carburetor but some are showing using the regulator between the pump and the carb and some are showing putting the regulator in the return line and the gas tank . Does it matter and what would make more sense ? I'm thinking between the pump and the carb with a "T" fitting also diverting the excess pressure back to the tank . Thank You for your response. Share this post Link to post Share on other sites
ebinmaine 70,740 #2 Posted December 4, 2020 I don't have an electric pump on any of my own tractors but it seems to me if you bought the Facet pump 1.0 to 2.0 PSI you would not need a regulator or a return line 2 Share this post Link to post Share on other sites
Man In Black 3 #3 Posted December 4, 2020 5 minutes ago, ebinmaine said: I don't have an electric pump on any of my own tractors but it seems to me if you bought the Facet pump 1.0 to 2.0 PSI you would not need a regulator or a return line Didn't know about that one . The lowest i could find was the 2.5 Who sells those ? Share this post Link to post Share on other sites
ebinmaine 70,740 #4 Posted December 4, 2020 Just now, Man In Black said: Didn't know about that one . The lowest i could find was the 2.5 Who sells those ? Not having ever bought one I don't have an immediate source to recommend but I would imagine if you googled Facet brand pump and find their correct part number you could get them at many sources online. Share this post Link to post Share on other sites
Racinbob 11,726 #5 Posted December 4, 2020 I used a Mr, Gasket #42s rated at 2-3.5 psi. No return line, works great. 3 Share this post Link to post Share on other sites
305 380 #6 Posted December 4, 2020 i do believe Facet makes a 1 to 2 PSI fuel pump , as said google should find many suppliers i have found that using an electric fuel pump with the correct PSI is better than adding a regulator. if the regulator Youtube videos show is one of those dial ones like that Mr Gasket sells they are total crap , i would not use it if you gave me one free. Holley makes an 1 to 4 PSI adjustable regulator that is actually good 2 Share this post Link to post Share on other sites
oliver2-44 10,367 #7 Posted December 4, 2020 I have a Facet 1-2 psi pump on my C160 and a spare on the shelf for the next one that needs one. No regulator It’s Facet # 05-10882 1 1 Share this post Link to post Share on other sites
cafoose 3,383 #8 Posted December 4, 2020 https://www.amazon.com/s?k=facet+fuel+pump&crid=1IKEY71X5MPS5&sprefix=facet%2Caps%2C259&ref=nb_sb_ss_ts-a-p_10_5 1 Share this post Link to post Share on other sites
Racinbob 11,726 #9 Posted December 4, 2020 1 hour ago, 305 said: i do believe Facet makes a 1 to 2 PSI fuel pump , as said google should find many suppliers i have found that using an electric fuel pump with the correct PSI is better than adding a regulator. if the regulator Youtube videos show is one of those dial ones like that Mr Gasket sells they are total crap , i would not use it if you gave me one free. Holley makes an 1 to 4 PSI adjustable regulator that is actually good I've heard about that adjustable one but the 42s is not adjustable. Share this post Link to post Share on other sites
305 380 #10 Posted December 4, 2020 yes..... it's the fuel pressure regulator sold by Mr Gasket that is adjustable , and not the fuel pumps they sell Share this post Link to post Share on other sites
pfrederi 18,333 #11 Posted December 4, 2020 Facet Posiflo made in USA several PSI ranges to choose from. https://www.aircraftspruce.com/catalog/eppages/solidstatepump.php 1 Share this post Link to post Share on other sites
roadapples 6,983 #12 Posted December 4, 2020 If you stay under 4psi you shouldn't have a problem. I use Facets 1.5 to 2.5 psi cube style. About $58 on eBay. Free shipping. 2 Share this post Link to post Share on other sites
peter lena 9,088 #13 Posted December 5, 2020 have a CARBOLE PUMP ON MINE , 2-3.5 GPH , looks exactly like the facet posi flow , pump , no return line . added a small LED single bulb to verify operation , instant start , no problems , pete Share this post Link to post Share on other sites
