oilwell1415 563 #1 Posted December 3, 2020 I've got a K181 with a fuel pump that I'm going to put on my 552 that currently has an H55 without a fuel pump. I don't have anything against a fuel pump, but any way you slice it a fuel pump is another item that can fail. I have never had gravity fail, so I'm wondering if there is a way to run the Kohler without a fuel pump. Is it just a carb swap? Is there some compelling reason that a fuel pump is just a better way to do things? I'm sure they use a pump for a reason, I just don't know what that reason might be. There have been thousands of tractor/engine combinations used without a fuel pump. If this is just a carb swap, which carb do I need? Alternatively, I guess I could mount the fuel tank on a 10 foot pole to get the 4psi, but that just wouldn't look very good. Share this post Link to post Share on other sites
ebinmaine 67,328 #2 Posted December 3, 2020 1 minute ago, oilwell1415 said: Alternatively, I guess I could mount the fuel tank on a 10 foot pole to get the 4psi, but that just wouldn't look very good I'd like very much to see the formula you've used to get the height of the pole figured out 1 Share this post Link to post Share on other sites
oilwell1415 563 #3 Posted December 3, 2020 3 minutes ago, ebinmaine said: I'd like very much to see the formula you've used to get the height of the pole figured out Well, it was basically a guess. But since you asked..... I know that 4.33 psi is equal to 10' H2O because my brain is full of that sort of useless (usually) crap. I also know that water weighs 8.3 lbs/gallon and gas weighs 6 lbs/gallon, so a column of gas would have to be 38% taller than a column of water to generate the same pressure. That means a column of gas at 4.33 psi would be 13.8 feet tall. If the pressure was dropped to 4 psi instead of 4.33 psi we would have 12.7 feet. The tank currently sits higher than the carb, so we can deduct a little from that measurement and get the length of the pole down to about 12 feet. I think I remember seeing that fuel pressure from 2.5-4 psi was acceptable, do dropping the length to 10 feet for a nice round number seemed reasonable. 2 1 1 3 Share this post Link to post Share on other sites
ebinmaine 67,328 #4 Posted December 3, 2020 1 minute ago, oilwell1415 said: reasonable Agreed Share this post Link to post Share on other sites
ebinmaine 67,328 #5 Posted December 3, 2020 But you may have to trim some trees... Seriously though. Maybe I'm a little off center here but I don't know why you NEED a fuel pump if it's a gravity drop. 1 Share this post Link to post Share on other sites
formariz 11,987 #6 Posted December 3, 2020 What is wrong with the H55? Don't trash that one. Share this post Link to post Share on other sites
oilwell1415 563 #7 Posted December 3, 2020 1 minute ago, ebinmaine said: Seriously though. Maybe I'm a little off center here but I don't know why you NEED a fuel pump if it's a gravity drop. Some carburetors have a spring loaded needle and seat that has to have a little fuel pressure to open. I don't know if this one is like that or not, but they are out there. Others are adapted from smaller engines and gravity won't push enough fuel for them to operate at high power levels, so they add a pump. I may just give this one a try without it and see what happens. Share this post Link to post Share on other sites
oilwell1415 563 #8 Posted December 3, 2020 1 minute ago, formariz said: What is wrong with the H55? Don't trash that one. Nothing, just going a different direction. I've got other plans for the Tec. Share this post Link to post Share on other sites
WHNJ701 4,165 #9 Posted December 3, 2020 3 minutes ago, formariz said: What is wrong with the H55? Don't trash that one. I am with you on that one, once that h55d on my 551 got sorted out it's great running engine 1 Share this post Link to post Share on other sites
formariz 11,987 #10 Posted December 3, 2020 You need a #22 Carter or Kohler carburetor. If it starts to get fuel starvation at higher RPMs you may need to get one with a larger venturi to increase air velocity and therefor increase fuel suction. The #22 already has a rather large venturi . I have experimented with this in the past with good results. Share this post Link to post Share on other sites
formariz 11,987 #11 Posted December 3, 2020 11 minutes ago, oilwell1415 said: Some carburetors have a spring loaded needle and seat that has to have a little fuel pressure to open That spring I believe is attached to float and it just allows float to force needle to open or close as it floats up and down . Prevents needle from getting stuck which happens many times. I don't believe it has anything to do with fuel pressure. I have used those with gravity fed systems that basically will not have much pressure when tank is about empty. Share this post Link to post Share on other sites
roadapples 6,983 #12 Posted December 3, 2020 I have a 1.5 to 2.5 psi electric pump on a 16hp and it's plenty... May be totally different. Just saying.... Share this post Link to post Share on other sites
ebinmaine 67,328 #13 Posted December 3, 2020 I'm fairly new to this Kohler engine repair in comparison to most of you. Been around engines of lots of various sizes all my life though. I'm not sure how many Kohler carburetors I've rebuilt but I would say maybe 8 or 10? Year range going from 68 or 9 up to the early eighties on the k582. I'm not saying anybody's right or wrong, just that NONE of the carburetors I've taken apart yet have had any sort of a pressure causing or pressure relief spring. Because of our hilly terrain I'm not sure that I could get away with running a 16 horse purely by gravity but I've had a week fuel pump on a Kohler eight which may have not been putting out anything at all and I've had Trina's original 657 Tecumseh engine going up and down some Fair steep hills for short periods of time which were gravity fed even if maybe not on purpose. Share this post Link to post Share on other sites
formariz 11,987 #14 Posted December 3, 2020 Even on a K91 with a fuel tank one gets fuel starvation when going uphill specially with a load. I have been witness to that and proved it by experimenting by installing pumps of various types in those engines. Any of these engines in question will work without a pump relatively well under “ normal “ circumstances, such as level terrain , and relatively low or no load . Change any of those conditions and it will faulter. I even have a 520H that with a two stage blower going up a 1/4 mile steep driveway will get fuel starvation half way up with a new vacuum pump. On way down under load, no problem. Change it to an electric pump. No problem whatsoever under any circumstances. 2 Share this post Link to post Share on other sites
wallfish 16,987 #15 Posted December 3, 2020 Use the same carb and just bypass the fuel pump to go gravity feed. Route the fuel line directly to the carb. Remove the pump and cover the hole with a plate and a gasket. 3 Share this post Link to post Share on other sites
953 nut 55,120 #17 Posted December 4, 2020 Lots of garde3n tractors like the Cub originals had an engine mounted tank and no fuel pump. You should be fine with gravity feed. 1 Share this post Link to post Share on other sites
8ntruck 6,993 #18 Posted December 4, 2020 Come to think of it, my 8n is gravity fed. Share this post Link to post Share on other sites
Greentored 3,201 #19 Posted December 4, 2020 If your fuel level is above the float level, you should be fine. Somewhat new to small engines with factory fuel pumps so someone correct me if I'm wrong, but believe if the bowl stays full that's all you need- no fuel pressure required at the needle, just flow. 1 Share this post Link to post Share on other sites
Greentored 3,201 #20 Posted December 4, 2020 ...or you could tap the fuel cap with a nipple, run a section of rubber hose, and just blow in it while riding around! 1 2 Share this post Link to post Share on other sites
wallfish 16,987 #21 Posted December 4, 2020 9 minutes ago, Greentored said: If your fuel level is above the float level, you should be fine. Somewhat new to small engines with factory fuel pumps so someone correct me if I'm wrong, but believe if the bowl stays full that's all you need- no fuel pressure required at the needle, just flow. Correct but you could have issues like Formariz wrote. Instead of blowing into the hose, how about connecting it to a bellow under your arm pit you can pump with your arm? It would be quite the entertainment for the neighbors! LoL 3 Share this post Link to post Share on other sites
ebinmaine 67,328 #22 Posted December 4, 2020 1 hour ago, Greentored said: ...or you could tap the fuel cap with a nipple, run a section of rubber hose, and just blow in it while riding around! 1 hour ago, wallfish said: Instead of blowing into the hose, how about connecting it to a bellow under your arm pit you can pump with your arm? Both great ideas gentlemen. I must admit Mr Fish's would give better comedic aesthetics because of the movement involved with the up and down motion of the arm so as to create air pressure. For that reason I'm going to give 51% favor although I have to admit seeing a person on a garden tractor with a big black rubber hose coming out of their mouth and going directly into the fuel tank would certainly raise an eyebrow for me.... 2 Share this post Link to post Share on other sites
Greentored 3,201 #23 Posted December 4, 2020 Truth be told, if you see me riding around with a tube connected to my mouth, the other end would be connected to one of those cup holder hats. 1 1 Share this post Link to post Share on other sites
ebinmaine 67,328 #24 Posted December 4, 2020 3 minutes ago, Greentored said: Truth be told, if you see me riding around with a tube connected to my mouth, the other end would be connected to one of those cup holder hats. ........ And a bellows under your arm 2 Share this post Link to post Share on other sites
oilwell1415 563 #25 Posted December 4, 2020 2 hours ago, Greentored said: If your fuel level is above the float level, you should be fine. Somewhat new to small engines with factory fuel pumps so someone correct me if I'm wrong, but believe if the bowl stays full that's all you need- no fuel pressure required at the needle, just flow. That is correct, but sometimes isn't that simple. Fuel pumped under pressure would result in a float level significantly higher than gravity feed. Nothing a float adjustment shouldn't fix. 1 Share this post Link to post Share on other sites
