ohiofarmer
Changing/filling transmission fluid is difficult
ohiofarmer
  Man, the fluid just keeps burping. What i did finally was to get out a new one gallon jug of 10W30 and punch a little hole in the tin seal. I then leaked it down the side of a tiny funnel in a on eighth inch stream using a handy dandy hose like attachment on the oil container. Of course the jug quit flowing after a time, so I took a drywall screw and "drilled a tiny air hole into the jug for make up air. i takes about an hour and about a half gallon to fill the transmission. Maybe more once I run it and use the hydraulic lift.
  I also thought about placing a tiny vinyl tube down the fill hole into the transmission to let the air out.
  What do you guys do?
Edited by ohiofarmer
953 nut
I have removed a bolt from the seat support as a vent with good results.
  • Like 4
Achto
pacer
:text-yeahthat: yup,  just remove one of these screws and it'll go right in.
JohnD
I leave the filter loose and can get about 3.5 qts into my Eaton 1100 before it starts leaking out.  At that point I tighten the filter and put the last quart in slowly.  It doesn't take all 5.5 qts for a refill.
