ohiofarmer 3,276 #1 Posted December 3, 2020 (edited) Man, the fluid just keeps burping. What i did finally was to get out a new one gallon jug of 10W30 and punch a little hole in the tin seal. I then leaked it down the side of a tiny funnel in a on eighth inch stream using a handy dandy hose like attachment on the oil container. Of course the jug quit flowing after a time, so I took a drywall screw and "drilled a tiny air hole into the jug for make up air. i takes about an hour and about a half gallon to fill the transmission. Maybe more once I run it and use the hydraulic lift. I also thought about placing a tiny vinyl tube down the fill hole into the transmission to let the air out. What do you guys do? Edited December 3, 2020 by ohiofarmer Share this post Link to post Share on other sites
953 nut 55,769 #2 Posted December 3, 2020 I have removed a bolt from the seat support as a vent with good results. 4 Share this post Link to post Share on other sites
Achto 27,751 #3 Posted December 3, 2020 50 minutes ago, ohiofarmer said: What do you guys do? This is what I use. The pump will screw on to most qt. bottles. https://www.amazon.com/Performance-Tool-W54150-Marine-Lower/dp/B00J4YL1RE/ref=asc_df_B00J4YL1RE/?tag=hyprod-20&linkCode=df0&hvadid=312064691975&hvpos=&hvnetw=g&hvrand=8230585922112083088&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019452&hvtargid=pla-450107450123&psc=1 2 Share this post Link to post Share on other sites
pacer 3,174 #4 Posted December 3, 2020 yup, just remove one of these screws and it'll go right in. 1 Share this post Link to post Share on other sites
JohnD 145 #5 Posted December 3, 2020 I leave the filter loose and can get about 3.5 qts into my Eaton 1100 before it starts leaking out. At that point I tighten the filter and put the last quart in slowly. It doesn't take all 5.5 qts for a refill. 1 Share this post Link to post Share on other sites
