slim67 2,735 #1 Posted December 2, 2020 I wanted to see who is running front wheel weights on their machines especially for winter. What do you have? Share this post Link to post Share on other sites
cschannuth 3,816 #2 Posted December 2, 2020 I have a set of Wheel Horse weights on my C-161. I have a 54 inch snow blade on there and it never flinches so I assume they are doing some good. My dad had the whole set so I put them on when I got the tractor from him. I think they’re pretty pricey today, especially if you have to have them shipped. I also have inside weights on the rears and the rear tires are fluid filled. I’ve never encountered a snowfall it couldn’t handle easily from a traction standpoint. 6 6 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #3 Posted December 2, 2020 15 minutes ago, cschannuth said: I have a set of Wheel Horse weights on my C-161. I have a 54 inch snow blade on there and it never flinches so I assume they are doing some good. My dad had the whole set so I put them on when I got the tractor from him. I think they’re pretty pricey today, especially if you have to have them shipped. I also have inside weights on the rears and the rear tires are fluid filled. I’ve never encountered a snowfall it couldn’t handle easily from a traction standpoint. Ags and tri-ribs with weights! Awesome! I've wondered if that might be a great combo, though I'd think I would need chains as well. I'm a huge fan of chains! My NH TC35 4wd is a different beast with chains! I just got some tri-ribs but I also what to try Wallfish's roller chains on the front too. Love your rear tires! What are they? 3 1 Share this post Link to post Share on other sites
WHX?? 48,834 #4 Posted December 2, 2020 Got a set on the plow mule. 3 4 Share this post Link to post Share on other sites
cschannuth 3,816 #5 Posted December 2, 2020 6 minutes ago, DennisThornton said: Ags and tri-ribs with weights! Awesome! I've wondered if that might be a great combo, though I'd think I would need chains as well. I'm a huge fan of chains! My NH TC35 4wd is a different beast with chains! I just got some tri-ribs but I also what to try Wallfish's roller chains on the front too. Love your rear tires! What are they? Before I paved my driveway I used chains. Once I put down the concrete in sections I actually found the chains would cause slippage and scarring. I took them off and never have looked back. I used to plow snow with my old 520 and it had just fluid in the rear tires on turf savers and it did great as well. I think my tires are Carlyle but I would have to go past the shed to see for sure. It’s been a while since I put those on there. 3 1 Share this post Link to post Share on other sites
squonk 41,166 #6 Posted December 2, 2020 7 minutes ago, WHX24 said: Got a set on the plow mule. Nice shin grabbers you got there! 4 2 Share this post Link to post Share on other sites
DennisThornton 4,769 #7 Posted December 2, 2020 3 minutes ago, cschannuth said: Before I paved my driveway I used chains. Once I put down the concrete in sections I actually found the chains would cause slippage and scarring. I took them off and never have looked back. I used to plow snow with my old 520 and it had just fluid in the rear tires on turf savers and it did great as well. I think my tires are Carlyle but I would have to go past the shed to see for sure. It’s been a while since I put those on there. One of the very fine benefits of this forum is not only the vast amount of knowledge, but the depth of different experiences AND the ability to ask and explain and fine tune are invaluable! I've pushed snow for decades but my driveway is crushed stone and I can see where your concrete would be different and that chains would perform differently on a hard smooth surface as well! My chains dig in EVEN in frozen hard packed gravel, but they would stop at a hard concrete surface and then I suppose have less surface area to grab! I'm still going to say studs or chains for ice, but perhaps not for blacktop or concrete. Thank you! I think that everyday that I learn something is a good day! I'm concerned that I might be forgetting more than I learning though and how long can I sustain that before... KEEP THE GREAT IDEAS COMING! 7 1 Share this post Link to post Share on other sites
slim67 2,735 #8 Posted December 2, 2020 54 minutes ago, cschannuth said: I have a set of Wheel Horse weights on my C-161. I have a 54 inch snow blade on there and it never flinches so I assume they are doing some good. My dad had the whole set so I put them on when I got the tractor from him. I think they’re pretty pricey today, especially if you have to have them shipped. I also have inside weights on the rears and the rear tires are fluid filled. I’ve never encountered a snowfall it couldn’t handle easily from a traction standpoint. Thats loaded down nicely! 33 minutes ago, WHX24 said: Got a set on the plow mule. I like it. Are those Gravely weights on the front? Do you know the weight? 2 Share this post Link to post Share on other sites
DennisThornton 4,769 #9 Posted December 2, 2020 I can't even begin to have a single set per rear and you have DUAL weights on the rear? 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #10 Posted December 2, 2020 The 315-8 set up for tilling... 4 1 Share this post Link to post Share on other sites
slim67 2,735 #11 Posted December 2, 2020 32 minutes ago, DennisThornton said: One of the very fine benefits of this forum is not only the vast amount of knowledge, but the depth of different experiences AND the ability to ask and explain and fine tune are invaluable! I've pushed snow for decades but my driveway is crushed stone and I can see where your concrete would be different and that chains would perform differently on a hard smooth surface as well! My chains dig in EVEN in frozen hard packed gravel, but they would stop at a hard concrete surface and then I suppose have less surface area to grab! I'm still going to say studs or chains for ice, but perhaps not for blacktop or concrete. Thank you! I think that everyday that I learn something is a good day! I'm concerned that I might be forgetting more than I learning though and how long can I sustain that before... KEEP THE GREAT IDEAS COMING! My driveway is asphalt but needs a topping in the future so Im not concerned about chains as I run a set on my tractor. I always have and so did my Dad but when I find a nice set of wider gas I will stop with chains especially after getting my driveway done. Share this post Link to post Share on other sites
slim67 2,735 #12 Posted December 2, 2020 3 minutes ago, WVHillbilly520H said: The 315-8 set up for tilling... Those fronts look like MTD weights. Thats what im putting on mine. 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #13 Posted December 2, 2020 3 minutes ago, slim67 said: My driveway is asphalt but needs a topping in the future so Im not concerned about chains as I run a set on my tractor. I always have and so did my Dad but when I find a nice set of wider gas I will stop with chains especially after getting my driveway done. Never used them but I've read good about the rubber "chains". 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #14 Posted December 2, 2020 14 minutes ago, slim67 said: Those fronts look like MTD weights. Thats what im putting on mine. Could have been in paid the man brought them home painted them the figured out only 1 bolt hole aligned up ... But they never came loose during tilling season. Share this post Link to post Share on other sites
SylvanLakeWH 25,609 #15 Posted December 2, 2020 For the reasons noted above regarding surface damage, I plow 3 flat driveways (1 concrete, 2 asphalt) with my C 105 with no weights or chains. No issues... 5 2 Share this post Link to post Share on other sites
slim67 2,735 #16 Posted December 2, 2020 7 minutes ago, SylvanLakeWH said: For the reasons noted above regarding surface damage, I plow 3 flat driveways (1 concrete, 2 asphalt) with my C 105 with no weights or chains. No issues... That's incredible. you must have the touch 1 Share this post Link to post Share on other sites
slim67 2,735 #17 Posted December 2, 2020 10 minutes ago, WVHillbilly520H said: Could have been in paid the man brought them home painted them the figured out only 1 bolt hole aligned up ... But they never came loose during tilling season. How far off was the other hole? It looks like they give you 3 options of which two looked like they should work. Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #18 Posted December 2, 2020 (edited) 5 minutes ago, slim67 said: How far off was the other hole? It looks like they give you 3 options of which two looked like they should work. My pair maybe 1/8- 3/16" and with a hand drill in just couldn't correct it enough maybe a drill press or milling machine and an endmill (I miss my old machine shop days) Edited December 2, 2020 by WVHillbilly520H Share this post Link to post Share on other sites
SylvanLakeWH 25,609 #19 Posted December 2, 2020 9 minutes ago, slim67 said: That's incredible. you must have the touch Well... thanks...! I’ve been told I’m “touched”... 5 Share this post Link to post Share on other sites
ebinmaine 67,711 #20 Posted December 2, 2020 9 minutes ago, SylvanLakeWH said: Well... thanks...! I’ve been told I’m “touched”... Me too bud. Me too. @slim67 I run oversized tires all around on the Cinnamon Horse. The fronts are 20 x 8 x 8 turfs with over 5 gallons of Rimguard each. Between the fluid (110 lbs+), bigger wheels, and larger tires I've probably added 120 lbs or more to the front of the tractor. On Trina's Pig Pen 867 I'm going to add a piece or 2 of steel weight in front of the frame. Each piece is 40 and 45lbs respectively. 1 Share this post Link to post Share on other sites
WHX?? 48,834 #21 Posted December 3, 2020 (edited) 1 hour ago, slim67 said: Thats loaded down nicely! I like it. Are those Gravely weights on the front? Do you know the weight? Thanks....I have no idea Slim... picked them up at a swap meet... thinkin Lane Ranger might have sold them to me ... or did I get the back ones from him???... I CRS. 1 hour ago, DennisThornton said: I can't even begin to have a single set per rear and you have DUAL weights on the rear? They are supposed to be inside wheel weights but just a burly one from going over the hub. Some day I'll peel them off and machine them a bit. Plow day was not waiting for me so threw the land side on outside. Lots of us plow dogs run dual weights. Hardcore furrow rats even run three or more plus loaded tires. Furrow side only has one. My wallet was as thick as Billy's I would have some suitcases off the front too. Edited December 3, 2020 by WHX24 5 Share this post Link to post Share on other sites
rjg854 11,389 #22 Posted December 3, 2020 I have 2 sets, front and rear. One set for the plow tractor and the other on the blower tractor. 4 Share this post Link to post Share on other sites
JoeM 7,874 #23 Posted December 3, 2020 The chains on the FEL mark the concrete just moving around. Tire weights and box weight 600, plus tractor and operator. Marks disappear pretty much by spring. The rest are gone when I use the rotating pressure head to clean. I used 1-1/2" front wheel weights on my old C145 and it does seem to give an odd sensation when steering. It helps on the slope to keep front end from sliding. 5 Share this post Link to post Share on other sites
Achto 27,623 #24 Posted December 3, 2020 8 minutes ago, WHX24 said: .I have no idea Slim... picked them up at a swap meet Are those the weights that you bought off from Joel?? Think they were on the back of a Simple City score that he got. Share this post Link to post Share on other sites
WHX?? 48,834 #25 Posted December 3, 2020 (edited) No I don't think so.... the only weights he gave me were the cutouts from the water jet. Those are ear marked for the front of the super C. Thinkin I got a set from Massey Jason???? Edited December 3, 2020 by WHX24 Share this post Link to post Share on other sites
